Matching fronts and rears? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-27-2014, 11:58 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 118 Post(s)
Liked: 34
I know it's very important to match the fronts with the center, but how important is it to match the surrounds and rear surrounds with the fronts??
Most of you know I just purchased 2 PB-2000's and the SVS center which sounds phenomenal. Next I will be grabbing a pair of the SVS Ultra bookshelf speakers for the fronts which are $499/each. I have no problem saving for them since my theater won't be finished for awhile, but is it worth saving to get matching rears as well??
Also, it will be a 7.2 system. So matching would make me dig a bit deeper into my pockets.
mpjmeyer is offline
post #2 of 5 Old 06-27-2014, 12:14 PM
Calypte's Avatar
For my HT, I use identical Boston A40 Series II all around. Yes, I know, these are 25 year-old speakers. But the sound field is seamless. I keep them alive with woofer repair kits and occasional new tweeters, all readily available on eBay.
Calypte is offline
post #3 of 5 Old 06-27-2014, 12:28 PM
DonH50's Avatar
Quoted: 1827 Post(s)
Liked: 1359
Since there is much less content in surrounds and rears, and much different content, I wouldn't worry too much about matching them. The front L/C/R I consider more important as so much of the dialogue and action spans or pans those three.
IMO - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 5 Old 06-27-2014, 12:49 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
It's not always possible to have matching rears speakers; they may not produce standmounts or dedicated surrounds, they're end of line.
fatbottom is offline
post #5 of 5 Old 06-27-2014, 12:50 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1686
My own view is that the surround channels are not very important. I don't think it makes a bit of difference whether they match anything or not.
FMW is offline
Reply Speakers
