I need advice about speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 07-02-2014, 06:08 PM - Thread Starter
Liked: 0
I am a little confused about what speakers I should get to go along with my Tascam PA-R200 receiver (100 Watts per Channel 8 Ohms, 20 Hz–20 kHz, 0.08% THD)
Do the speakers have to have a lower watts than 100? some say watts between 20-200.
Do they have to be 8 Ohms speakers?
I am a bit of a noob to this. thanks.
Nyrus is offline
post #2 of 20 Old 07-02-2014, 06:16 PM
zieglj01's Avatar
Quoted: 1573 Post(s)
Liked: 1430
What is your budget?
Are you looking for bookshelf or towers - and how large is the space?
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #3 of 20 Old 07-02-2014, 06:26 PM - Thread Starter
Liked: 0
no more than $400 for a pair I guess.
I was looking at these towers, but not sure it they will work with my receiver.
Polk Audio Monitor 65T Three-Way Ported
Energy CF-30 Floorstanding/Tower Speaker
Onkyo SKF-4800 2-Way Bass Reflex
Klipsch Synergy F-20 Premium Dual 6.5-Inch Floor-Standing Speaker
Klipsch Icon VF-35 Floorstanding Speaker
Yamaha NS-F150 Floor Standing Speakers
My media room is pretty small.
Nyrus is offline
post #4 of 20 Old 07-02-2014, 06:52 PM
zieglj01's Avatar
Liked: 1430
That is a lot of receiver, based on your budget for speakers
Any of them speakers will work with that rebranded (Teac/Onkyo) Tascam receiver
In general, look for speakers rated 6 ohms and up.
Who AM I
post #5 of 20 Old 07-02-2014, 06:58 PM - Thread Starter
Liked: 0
Shouldn't i worry that the receiver is 8 ohms? And I heard I need to make sure the speaker watts are lower than the amp, so if my receiver says 100 w and channel, my speakers need to be below 100 w? If so, that really cuts down on what I can buy.
And yes, the receiver is nice but i got it a price i couldn't refuse.
Nyrus is offline
post #6 of 20 Old 07-02-2014, 07:19 PM
zieglj01's Avatar
Liked: 1430
It is in reality an Onkyo/Integra receiver - it will take care of business
Your speakers can be 6 ohms - do not worry
Your speakers can be higher than 100 watts - do not worry
The Receiver can handle dynamic peaks for 4/6/8 ohm loads - do not worry
Just make sure the receiver has good ventilation around it.
Yes the prices are good for the Tascam receivers - they have been discontinued.
Who AM I
post #7 of 20 Old 07-03-2014, 05:53 AM - Thread Starter
Liked: 0
Thanks. Then I think I will go with the Energy CF-30s. It blows that i can't listen to any of them since I am buying them online. So of anyone has any inputs on the speakers I want to buy or have alternatives in mind, please let me know. Thanks.
Nyrus is offline
post #8 of 20 Old 07-03-2014, 06:19 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
You don't have to worry about matching, only if one or more of the following
a) Your amp has low power
b) Your speakers have low sensivity
c) Your speakers have low impedance
d) You have a large room
fatbottom is offline
post #9 of 20 Old 07-03-2014, 07:14 AM - Thread Starter
Liked: 0
Does anyone know anything about HTD speakers? how do they rank compared to other brands in reliability and sound?
Looking at these http://www.htd.com/Products/tower-sp...Tower-Speakers
Nyrus is offline
post #10 of 20 Old 07-03-2014, 07:33 AM
Elihawk's Avatar
Quoted: 1327 Post(s)
Liked: 1161
I haven't heard the HTD speakers, but have been told by several people who has heard them or owned them, that if you can step up to the level 3 speaker, the ribbon tweeter is outstanding!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
post #11 of 20 Old 07-03-2014, 07:43 AM - Thread Starter
Liked: 0
Yea but if i as going to go that high i would just buy the Energy CF-70
Nyrus is offline
post #12 of 20 Old 07-03-2014, 08:07 AM
zieglj01's Avatar
Liked: 1430
Yes HTD makes good stuff - and would be my preference
Your call
Who AM I
post #13 of 20 Old 07-03-2014, 09:33 AM - Thread Starter
Liked: 0
a) My amps state 100 watts a channel
b) Looking at speakers with 90+ sensivity
c) Looking at speakers that are 6 or 8 Ohms
d) the media room is small. 9 x 13
Nyrus is offline
post #14 of 20 Old 07-03-2014, 09:34 AM - Thread Starter
Liked: 0
Your call
even the level 2s?
Nyrus is offline
post #15 of 20 Old 07-03-2014, 09:51 AM
zieglj01's Avatar
Liked: 1430
even the level 2s?
Yes, and your receiver will drive them - HTD is good for the money.
They will get loud in that room
Who AM I
post #16 of 20 Old 07-03-2014, 11:35 AM
zieglj01's Avatar
Liked: 1430
I decided to also buy that receiver - $188 new on Ebay
Who AM I
post #17 of 20 Old 07-03-2014, 11:56 AM - Thread Starter
Liked: 0
You probably bought it from the same guy. no one else is selling it for cheap.
I also now thinking about going to bestbuy and getting these
They are on sale today. What do you think of them?
Nyrus is offline
post #18 of 20 Old 07-03-2014, 02:24 PM
zieglj01's Avatar
Liked: 1430
I am not a big fan - however, you may like them.
The only towers I would buy from Best Buy, is the Sony Core speakers
http://www.bestbuy.com/site/sony-cor...kers&cp=1&lp=3
However, for a tight budget the Pioneer FS52 towers are nice.
Who AM I
post #19 of 20 Old 07-03-2014, 04:43 PM - Thread Starter
Liked: 0
I went ahead and got the ones I posted since the sale was just for today. I figured I will test them out. They do sound a bit harsh at times and other times they sound smooth, depending on the song. So trying to figure them out.
Nyrus is offline
post #20 of 20 Old 07-03-2014, 04:52 PM
hedrick's Avatar
In general the only real power-related danger is that if the receiver doesn't have enough power, and you listen loud, you can push the receiver beyond it's limits. That can produce a kind of distortion that is dangerous to speakers.
With typical consumer speakers, it's unlikely that 100 watts will be too little power. There's no standard for how to rate speaker power handling. That means that you can't really use the ratings for much. Sensitivity is more useful, in the sense that it will help you guess how much power it's going to take the drive the speakers to the volume you want. But with a 9 x 13 room there's very little danger of overloading a 100 watt amp, unless you do something very weird.
8 ohm speakers often go down to 6 or less at times. An amp designed for 8 ohm speakers will take that into accounts. The main issue is with 4 ohm speakers and a receiver that isn't designed for 4 ohms. You might look up a review of the receiver. They'll typical test receivers at both 8 and 4. The fact that a receiver says "100 watts per channel into 8 ohms" doesn't mean there's anything wrong with using 4 ohms. They're just telling you how the 100 watts was measured. There should be a separate specification that says whether it's rated for 4 ohms. But really, I'd try to use a review rather than the specifications.
hedrick is offline
Reply Speakers
