Best Cinema Speakers Match - AVS Forum | Home Theater Discussions And Reviews
Old 07-03-2014, 05:33 AM - Thread Starter
Liked: 0
Exclamation Best Cinema Speakers Match
I am setting up a home cinema. what is the best combination of speakers, subs, and amps to go with the JBL 3732.
Siddharth Mahadevan is offline
Old 07-03-2014, 07:05 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
There really is no answer to your question. However, that speaker is VERY sensitive, so a couple points...
1. You won't need a ton of power, some most any AV Rec will give you enough power to man the fronts.
2. You may want to get additional speakers that have at least low 90s sensitivity, or it may be very hard for your AVR to EQ and give all the speakers enough volume. JBL530s?
3. You will want to have three indentical across the front...unless I am missing a matching horizontal center.
4. You will want a powerful sub that puts out some output to keep up with these speakers. SVS, Rythmics, PSA, Reastion Audio or HSU, but nothing 10 inch or low end.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
Old 07-03-2014, 07:11 AM
Liked: 0
Curious, why does he need the front 3 to match?
Nyrus is offline
Old 07-03-2014, 07:20 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
You should match front three, as pans across the front would sound different, if you have totally different speakers from different brands
I've kept the front three the same.
fatbottom is offline
Old 07-03-2014, 10:00 AM
smurraybhm's Avatar
Quoted: 1469 Post(s)
Liked: 1760
One article to help answer that question. Matching fronts help present a seamless soundstage which is important for HT and multi-channel audio. Many feel strongly about matching all of your surrounds - but depending on the room, speakers you have up front, that isn't always possible.
http://www.soundandvision.com/conten...round-speakers
smurraybhm is online now
Old 07-03-2014, 10:30 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Also look at the JBL LSR6332
http://www.sweetwater.com/store/sear...6332&Go=Search
You can also search here -
JBL Cinema 3722/4722 vs QSC KW-153 active speakers for HT
http://www.avlgear.com/search.php?se...&x=-1070&y=-62
JBL 3677 vs JBL 3722N for LCR
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
cinema , Jbl , jbl3732 , speakers , theatre
