speaker stand base too small for B&W 602s? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-08-2014, 11:17 AM - Thread Starter
Liked: 0
I'm looking at a used pair of these stands for $60 locally:
http://www.visions.ca/catalogue/cate...=256&sku=em500
The base is only 6" and my speakers are 11.5" deep x 9.3" wide, 23 lbs. each.
The seller has B&W 685s which are 12.8" deep x 7.5" wide and says that's fine but doesn't know about my speaker size.
I plan on filling the stand columns with sand for added stability. Would this stand be sufficient to hold my speakers??
parksung is offline
post #2 of 2 Old 07-08-2014, 02:04 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
You should be fine. Anchor the speakers with some blue tack, or similar adhesive putty.
crn3371 is online now
Reply Speakers
