balanced or unbalanced cable for stuio monitor? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Bill Fitzmaurice
  • 1 Post By DonH50
post #1 of 12 Old 07-08-2014, 11:50 AM - Thread Starter
enuff4life's Avatar
my current setup is
Computer source -> Presonus audiobox -> JBL lsr2310 Sub -> JBL lsr305 monitors
Do I must have balanced cable for this setup? Would I hear difference between balanced and unbalanced cables? the wires are running short ~3ft for home studio
enuff4life is offline
post #2 of 12 Old 07-08-2014, 11:58 AM
Bill Fitzmaurice's Avatar
Liked: 4135
Even in short lengths you should use balanced connections when you have the option, as they increase headroom by 6dB, and eliminate the possibility of ground loop noise. In a perfect world there would be no such thing as unbalanced.
http://www.rane.com/note110.html
Bill Fitzmaurice is online now
post #3 of 12 Old 07-08-2014, 07:42 PM - Thread Starter
enuff4life's Avatar
Would 1/4 balanced with two strip to xlr cable be work out ok?
post #4 of 12 Old 07-08-2014, 07:50 PM
Liked: 4135
Balanced is balanced. The only difference between TRS 1/4" and XLR is the connector.
Transmaniacon likes this.
post #5 of 12 Old 07-09-2014, 06:49 AM
DonH50's Avatar
Quoted: 1659 Post(s)
Liked: 1205
Note while the benefits Bill stated of balanced are generally true, they do not necessarily increase headroom by 6 dB (depends on the circuit design), and do not always break ground loops (though most designs give you the option of doing so). Most designs will improve SNR by 3 - 6 dB compared to their single-ended inputs, and do allow you to lift the ground at one end to break a loop.
That said, I agree with Bill there is really no drawback to using balanced if you have the means, and 1/4" TRS and XLR are the same electrically (XLR has more positive capture mechanically but the signal pins aren't much better than using TRS at line levels).
I do not know what you mean by "two strip". A balanced cable with two conductors surrounded by a shield in one is better than two independent coax cables.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #6 of 12 Old 07-09-2014, 08:18 AM
epepin's Avatar
Quoted: 40 Post(s)
For subs, does balanced v unbalanced make more or less of a difference? Would you suggest only considering options with balanced input? Or is the LFE channel something else entirely?
epepin is offline
post #7 of 12 Old 07-09-2014, 08:53 AM
DonH50's Avatar
Liked: 1205
I would say the same except that in practice subs tend to be connected by longer runs, and often plugged into a different outlet, so balanced may benefit more in those situations. However, many people run subs with single-ended cables without problem. I would not use the word "only". I would use balanced if available but would not base my decision solely, or even primarily, on that feature.
Handwaving explanation: The low frequency effects (LFE) channel is specific to movies that use the ".1" channel and it is sent to the subwoofer by default. Most AVRs incorporate bass management that can route the LFE content to the L/R speakers if they are set to "large" (rarely recommended as most speakers of any size benefit from having the sub handle the LF signals). Bass management will also usually send LF content below the crossover setting from all other sources (CDs, streaming music, record players, etc.) to the sub. Note the LFE crossover setting and main crossover setting may be different in your AVR; some combine the two into one global setting, some do not.
YMMV - Don
epepin likes this.
DonH50 is offline
post #8 of 12 Old 07-09-2014, 12:39 PM
Liked: 4135
Because of the distances involved between a typical AVR and the sub amps this is where balanced would be of most benefit, to eliminate the possibility of a ground loop. But balanced AVR sends and sub inputs are exceedingly rare. Not the least bit coincidental is that ground loop noise is the number one issue facing AVR/sub owners. The subwoofer forum abounds with threads asking how to fix it.
post #9 of 12 Old 07-20-2014, 10:25 PM
epepin's Avatar
Quoted: 40 Post(s)
Sorry to revive and oldish thread. I know a simple XLR-RCA adapter would permit a balanced signal to travel from an XLR output to an RCA input on a sub, but is there some sort of powered adapter or some such thing that would complete the balanced transmission over the long distance and offer an RCA for a short line to the sub? Would this even help with ground loop noise? Thanks.
epepin is offline
post #10 of 12 Old 07-20-2014, 10:51 PM
Marc Wielage's Avatar
Quoted: 234 Post(s)
Liked: 131
I'd vote for balanced as well if you have the choice.
If you're converting from unbalanced, then going to a balanced line and converting back to unbalanced, you're going to lose most of the advantages in going all balanced.
Marc Wielage is offline
post #11 of 12 Old 07-21-2014, 04:56 AM
LeightonBeck's Avatar
Quoted: 16 Post(s)
I use one of these : http://artproaudio.com/artcessories/.../cleanbox_pro/
and one of these: http://artproaudio.com/artcessories/...s/product/dti/
although in your case one of these would be good too.: http://artproaudio.com/artcessories/...uct/av_direct/
These are handy little problem solvers that don't cost much. You can get cheaper no brand or Berhinger models. Radial make the best with transformers similar to those found in MC phono preamps.
I converted my entire systems over to balanced cabling over a period of 4-5 years using these boxes as temporary solutions while slowly upgrading various components to have balanced I/O .
LeightonBeck is offline
post #12 of 12 Old 07-21-2014, 06:27 AM
DonH50's Avatar
Liked: 1205
You could also use a passive transformer. Plenty of them around from <$50 (Radio Shack) to >$1200 (Jensen and a few others).
As a class many of these devices are called direct, direct interface, or DI boxes.
HTH - Don
edit: Just caught that one of the Art devices in LeightonBeck's post above is a transformer DI box, too.
DonH50 is offline
Reply Speakers
