How much separation needed for L and R? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-11-2014, 05:03 AM - Thread Starter
Ewingr's Avatar
Quoted: 62 Post(s)
I'm leaning toward in-ceiling speakers for LCR, one reason being that I'm thinking tht the 6' cabinet doesn't provide enough separtion between L and R. My current cabinet is 110", but won't have that when I move.
But, I'm really wondering if that less separation is really a big deal.
If that separation seems OK, then I'll need to consider what bookshelf/center I need to settle on.
I will be going with in-ceiling for the rears.
Ewingr is offline
post #2 of 8 Old 07-11-2014, 05:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Missing from your question is even the slightest clue as to what your listening location is going to be. First cut at LR placement is that the speakers should be at the two outer tips of an equilateral triangle, with you sitting at the apex.
If you are only going to sit a few feet away, then 6' could be fine. Most people are not sitting that close.
The biggest problem that I see with in-ceiling speakers for the LCR is that you are unlikely to be anything like on-axis of them in your preferred seating location. At the minimum, in-wall would appear to be a far better choice.
arnyk is offline
post #3 of 8 Old 07-11-2014, 06:10 AM
ALtlOff's Avatar
Quoted: 1126 Post(s)
Liked: 565
The Audioholics formula is this:
Measure the distance from your center channel to you
Multiply that by .3 and .6, this will give you minimum and maximum distances from center.
Ex. 72" x .3 = 21.6
72" x .6 = 43.2
So anywhere from about 2' to 4 1/2' from center for each speaker should be good.
ALtlOff is offline
post #4 of 8 Old 07-11-2014, 06:32 AM
commsysman's Avatar
Quoted: 1079 Post(s)
Liked: 567
The listening position and the two speakers should form an equilateral triangle.
If you sit much further away than that, you will lose some separation.
commsysman is offline
post #5 of 8 Old 07-11-2014, 09:13 AM
Bill Fitzmaurice's Avatar
Liked: 5619
I'm leaning toward in-ceiling speakers for LCR, one reason being that I'm thinking tht the 6' cabinet doesn't provide enough separtion between L and R..
Don't put the L/R in the cabinet. Stand or wall mount them. They should be separated enough so that they image as distinct left/right, which ideally means they're about the same distance apart as you are away from them. Using in ceiling to get that distance is a bad idea, as in ceiling speakers image very poorly. The same applies to the center. Some in ceilings do image OK, those contained in real enclosures that hang down and are angled to aim at the LP, but those tend to be expensive for what you get.
Bill Fitzmaurice is online now
post #6 of 8 Old 07-11-2014, 10:46 AM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 740
22 to 30 degrees:
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #7 of 8 Old 07-11-2014, 12:44 PM
RayGuy's Avatar
Quoted: 891 Post(s)
Liked: 760
If you have a lot of stuff between your speakers, you will not get good performance. Your speakers should have some air around them, be forward of the cabinet/TV, and be somewhat toed in so that the intersection is slightly forward to slightly behind your seated head. Also, getting them off of a cabinet and on to independent stands should help a lot.
If you experiment with positioning, wider/closer, forward/back you will find a "sweet spot" that allows the speakers to perform at their best. Once you have found the best positioning, then you can really evaluate the speakers and the need to replace them.
Also, I agree with the previous posters, avoid in-ceiling fronts at all costs.
RayGuy is offline
post #8 of 8 Old 07-11-2014, 01:00 PM
carp's Avatar
Quoted: 2782 Post(s)
Liked: 2088
I always preferred the triangle setup until my last 2 pairs of speakers. I've gone back and forth so many times but I always end up wanting to be closer to them than they are from each other. My head is 9' 6" from the front baffles and the distance of the inside edge of each toed in speaker is 11' 4" apart.
100 agree with what others are saying, if there is anyway you could go with anything besides in ceiling speakers - do it!
carp is offline
Reply Speakers
