need a recommendation for a bookshelf pair for stereo music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-11-2014, 02:15 PM - Thread Starter
Liked: 0
Question need a recommendation for a bookshelf pair for stereo music
Hi,
I was considering floor standers, but since I have a small-ish room (14x20) i think i would get better bang for the buck with shelf speakers... Anyway I'm looking for a pair around $600-$800 (i live in NYC) for stereo music listening only (no home theater). I was thinking something natural sounding because I mostly listen to jazz.. Also, they will play solo for now, without a sub so I need something that won't need a sub to play nicely..
I saw the klipsch reference series is in my budget but reviews say that they are not really natural, really bass heavy and too forward.. Also i saw B&W 600 series... Considering that too... what do you say?
Any other good value recommendations?
nadav2605 is offline
post #2 of 8 Old 07-11-2014, 02:21 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
I'm a big fan of the 600 series, especially for music. Take a look at the 685's. I'm using 684's for fronts in my home theater and I've been very happy with them.
crn3371 is offline
post #3 of 8 Old 07-11-2014, 02:30 PM
dsrussell's Avatar
Quoted: 2225 Post(s)
Liked: 3020
Actually, your room falls into the medium size category (1,500 - 3,000 cu. ft), so you're asking quite a bit from bookshelf speakers without a subwoofer. I'm sure there are several good bookshelf speakers that "may" fill your needs, but you will need to audition them to see for yourself. For $600 you might take a look at the Def Tech Studio Monitor series (the SM-55 or the SM-65 for a couple hundred more). Here are a couple of reviews:
http://hometheaterreview.com/definit...r-55-reviewed/
http://www.stereophile.com/content/d...55-loudspeaker
I haven't auditioned the speakers you mentioned, but I've auditioned the SM-55 and was nicely surprised, but you need to be the judge. I also preferred the SM-55 over the SM-65, but again, that's just me. You'll also want to audition several other bookshelf speakers in order to get a solid comparison. You can audition the Def Techs at Best Buy's Magnolia centers. Keep in mind that you'll probably need some decent speaker stands as well.
dsrussell is online now
post #4 of 8 Old 07-11-2014, 02:30 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 196
charmerci is offline
post #5 of 8 Old 07-11-2014, 04:00 PM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
Originally Posted by nadav2605 View Post
Hi,
If you can stretch the budget to $850 - then the Philharmonitors - designed by a musician,
who plays in an orchestra >> Shipping is included
http://philharmonicaudio.com/folio-m...bookshelf.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 8 Old 07-11-2014, 04:07 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Originally Posted by charmerci View Post
+1
sdg4vfx is offline
post #7 of 8 Old 07-11-2014, 05:03 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
If you like the 600 series, see if your local dealer will part with the floor models of the CM1's. They're definitely a step up, particularly for music. I got mine for pretty close to your price range. Most dealers are glad to re-cycle their demos once a year, so if their CM's have been there a while, you may get a deal.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
post #8 of 8 Old 07-11-2014, 11:47 PM
ALtlOff's Avatar
Quoted: 1044 Post(s)
Liked: 501
If this is your choice I'd go SM-65 and watch E-Bay, you can usually get a pair (or make a pair out of singles) of factory referbs for around $600.00
ALtlOff is offline
Reply Speakers
