--- > has anyone ever seen these speakers before??? - AVS Forum | Home Theater Discussions And Reviews
Old 07-12-2014, 04:15 AM - Thread Starter
richabi's Avatar
Quoted: 31 Post(s)
Liked: 5
check out these towers
Sherwood Tower Speakers - $800
http://houston.craigslist.org/ele/4553715159.html
They're gorgeous.
I know sherwood makes decent receivers and components for other brands. I know the speakers are only available over seas in Australia and other countries. Hardly anything is known here in the states.
I have read they are decent speakers to they are great value speakers & a few they're junkreviews.
Problem is...I can't seem to find these specific towers. The seller says he got them in Dubai where they are really popular. He gave me model numbers sp8300 & sp3600. Claims they sound amazing and uses a def tech mythos 10 cc for timber matching. He also claims they were 2 grand a speaker and 200 watt per channel speaker and the cabinets alone are worth 3x his asking price...
Scary to even consider a speaker I can't find replacement parts for let alone the specs.
I need y'all. I'm so curious. I need to know about these speakers.
Thank you!
richabi is offline
Old 07-12-2014, 01:56 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
I'd try contacting Sherwood directly and asking them about the speakers. Give them the model number and tell them you just want to know if they're legit.
www.sherwoodusa.com/
www.sherwoodusa.com/aboutus/aboutus.asp
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
Old 07-12-2014, 02:34 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Wow, new one on me.
They may be ok, but I'd be concerned that they're all looks and little performance. Honestly, no idea.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 07-12-2014, 04:33 PM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
They're gorgeous.
Thank you!
Sherwood, in general, makes low-priced junk. As far as I can tell, nothing they make is particularly "decent". Their product support is almost non-existent.
There is no way I would spend $800 on something used with unknown quality, especially with the Sherwood name. He can claim anything he wants to, can't he?
The model numbers, if they are correct, are no doubt european model numbers.
In Dubai, where every other guy is an oil millionaire, some real crap is sold to the unwary for ridiculous prices, so Dubai prices mean nothing.
I suggest that you stick to well-known products from a speaker manufacturer with a great long-term track record, like KEF, PSB, Monitor Audio, Vandersteen, or Focal.
commsysman is offline
Old 07-12-2014, 05:08 PM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 860
For that price, you can get a nice pair of speakers that ARNT a huge question mark! I would walk away from that one and while I don't agree with Commysman that Sherwood is junk, they aren't know for high end either...
Elihawk is offline
Old 07-12-2014, 05:28 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Sherwood is popular in other countries - it can not hurt to listen to them
I would not be quick to call them junk.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 07-12-2014, 05:33 PM - Thread Starter
richabi's Avatar
Quoted: 31 Post(s)
Liked: 5
Thank you everyone for all your knowledge and prompt replies.
There is a guy a bit further that has a monitor audio radius 5.0 (tower for mains) for only 20p. Think I'll pick that up until I find something specific
richabi is offline
Old 07-12-2014, 05:39 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
That is a good option - the Radius is nice
Who AM I
zieglj01 is offline
Old 07-13-2014, 08:57 AM
darthray's Avatar
Quoted: 942 Post(s)
Liked: 897
They're gorgeous.
Thank you!
After taking a quick look at some link.
I notice solid wood!
A speaker should not made of solid wood since it is not an intrument but try to reproduce sound.
Therfore it should be made of MDF or marine ply-wood.
Violon, guitar are made with solid wood.
But they are made to produce a sound.
A speaker is suppose to Re-produce a sound and not make sound of their own!
I would stay away from any speakers with solid wood (other than the few that use it for cosmatic on the outside, but use MDF inside).
Just a thought
Ray
darthray is offline
Old 07-13-2014, 09:18 AM
punprankster's Avatar
interesting that someone would claim to have bought these speakers for $8k but then sell them for only $800. says a lot about the legitimacy of the post.
punprankster is offline
Old 07-13-2014, 04:42 PM - Thread Starter
richabi's Avatar
Quoted: 31 Post(s)
Liked: 5
Well said, gentlemen
Solid points
richabi is offline
