Need CC recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-13-2014, 08:16 PM - Thread Starter
polomaan's Avatar
Just moved, left in-wall speakers, setup change required. I have a Pioneer VSX-1019AH, Energy CB-20 fronts, Klipsch 12" sub, no surrounds yet (will likely go without for a few months until I figure out what I want).
CC: needs to be <9" in depth to rest on our mantle, preferably less than 8".
Looking at: Energy CC-5 (10 won't fit), Definitive Technology Procenter 1000 and 2000.
Advice? Thanks!
polomaan is offline
post #2 of 3 Old 07-14-2014, 04:40 AM
Elihawk's Avatar
Quoted: 1340 Post(s)
Liked: 1172
Your front stage needs to match, so either find a way to make the Energy center work, or replace your entire front around a center that will.
Elihawk is offline
post #3 of 3 Old 07-14-2014, 04:46 AM - Thread Starter
polomaan's Avatar
Can't replace fronts currently. Maybe I'll give the Energy CC 5 a try since I can return to BB if it's not up to the task. I'm skeptical.
polomaan is offline
Reply Speakers
