Which KEF front speaker combo? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-14-2014, 09:36 PM - Thread Starter
mjc2020's Avatar
Which of these is the better option? I can get both of these options for within $100 of each other.
Option 1) 2 KEF Q300s paired with a Q600c
Option 2) 2 KEF Q500s paired with a Q200c
Option 2 is approximately $100 more expensive (mostly shipping cost). The Q500s are discounted to $299 which is a crazy price.
This would be upgrading legacy KEF Q1 series. I have never owned floor-standing speakers before.
Here are some details to help in answering:
1. Budget: N/A - I am OK with the pricing ~$1000
2. Size requirements/limits: None
3. Room dimensions. Approx 18x30 with 8 - 9 ft ceilings and a couple of openings
4. Primary uses. 100% Home Theater
5. Listening habits. I do like some bass and since this is a dedicated home theater in the basement, I do tend to have the volume up pretty high.
6. Appearance requirements. Don't care as long as it sounds good.
7. Other Info: Denon AVR-1613; Definitive Technology Pro Sub 1000; KEF surrounds
Thanks in advance for the help! I really appreciate it.
mjc2020 is offline
post #2 of 4 Old 07-16-2014, 12:49 PM
sdg4vfx's Avatar
Quoted: 80 Post(s)
Liked: 140
For primarily HT/surround listening (movies, multi-channel music, etc.) both options are good with maybe a slight edge to option 2.
Couple other thoughts ...
For dedicated HT/surround listening the ideal (though not commonly achieved) setup is three identical speakers across the front - gives you a seamless front sound stage. Some better options might be ...
- Three Q300's across the front as your LCR (if center channel space is an issue - unlike most speakers the Q300 can be laid on it's side without compromising sq)
- Three Q200's or Q600's across the front as LCR.
Another consideration - that's a fairly large space and a new, better sub (or 2) would noticeably improve your bass.
sdg4vfx is offline
post #3 of 4 Old 07-19-2014, 02:21 PM - Thread Starter
mjc2020's Avatar
Thanks for the reply. I ended up holding off on the purchase. Interesting thought on using the same 3 speakers across the front...
Yeah, the sub isn't the greatest - I have considered upgrading to a PVS, Rythmik or Outlaw but have yet to pull the trigger.
mjc2020 is offline
post #4 of 4 Old 07-19-2014, 02:50 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Personally since you already have Q series why side step to Q series? Go for R series
fatbottom is offline
Reply Speakers
