Help complete this home theater setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-15-2014, 02:00 PM - Thread Starter
Liked: 0
Question Help complete this home theater setup
Hi and thanks for viewing my post.
Please share your opinions on the best combination of speakers and sub woofer for a very nice home (possible jaw drop) theater sound.
Room: 13 X 13 X 8 @ 1352 cubic feet. Carpet.
Projector + 110 screen
Receiver: TX-NR809 – Onkyo
I have the following Speakers listed by $ high to low:
Bookshelf: 2 X JBL L830
Center: Energy Veritas 5.2C
Bookshelf: 2 X Energy C-100B-1
Center: Energy C-C50B-1
Surround: 2 X Energy C50B-1
Sub: Energy ESW-8
I need your help on putting together the best combination of speakers and sub. I can buy additional speakers and sub depending on your suggestions. I have about $1000-2000 to spend to complete my system. I hope to at least use some of my existing speakers. This is used 95% for movies.
Should I use the 2 JBL L830s as fronts and buy a JBL LC1 or JBL LC2 and use 2 X Energy C50B-1 for surrounds?
Should I use Energy Veritas 5.2C and buy additional Veritas speakers?
Should I start off clean and buy a whole set?
I am in the bay area and craigslist has lots of stuff posted but I am not sure what a good value is.
I also would like to meet fellow enthusiasts in the san fran bay area.
Thank you very much for your input.
careandsharelife is offline
post #2 of 10 Old 07-15-2014, 02:35 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
fwiw, in your budget take a look at the hsu hybrid3 5.1package http://www.hsuresearch.com/products/hybrid3pkg.html
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 10 Old 07-15-2014, 02:46 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Sub: Energy ESW-8
I would go with the JBL LC2 center channel to complete the front.
Check with HSU Research for a 12 inch subwoofer (based on budget) - like the VTF-2 or VTF-3
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 10 Old 07-15-2014, 06:44 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
I agree. The Energy Veritas are next to impossible to find now.
The Outlaw LFM-1 Plus is currently on sale for $499 shipped. Best value for you at the moment, and definitely will provide a wow factor in improvement over your Energy 8" sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 10 Old 07-15-2014, 07:35 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
+1, killer deal right there.
shadyJ is offline
post #6 of 10 Old 07-15-2014, 07:43 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
+2 on the Outlaw sub - and will help with the budget
Who AM I
zieglj01 is offline
post #7 of 10 Old 07-16-2014, 01:41 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
With $2000 and given your existing speakers, I'd recommend a staged upgrade. There's no need for a clean sheet straight away. All this will do is force you to spread your budget across 5 or 7 speakers rather than a few. The front 3 are by far the most important, particularly when movies are your dominant use (subs notwithstanding).
A new front end consisting of 3 x Ascend Acoustics CMT-340 SE M/C's plus a pair of Rythmik Audio LV12R subs will come to $1980 shipped (with discounts). The Outlaw LFM-1 Plus on special is tough to beat though. The three Ascends plus a pair of the Outlaws comes to $1940 shipped. You'd be very happy with either option. Six matching 6.5" woofers across the front will give you an excellent level of HT performance for around $900.
As far as surrounds go, you don't mention whether you're aiming for a 5.1 or 7.1 configuration. Ultimately, you'd head for a pair (or two) of Ascend's CBM-170 SE's and/or HTM-200 SE's depending on your application. The 200's are a compact, sealed speaker more suited to near, or on-wall applications. The 170's are a more capable speaker, but more suited when you have the available room.
For surrounds/rears in the interim, experimentation and listening is the key. There's not really a wrong answer. For a 5.1 configuration, try both the JBL's and the Energy C-100's as surrounds and see which you prefer. For a 7.1 configuration, try the C-100's and C-50's as surrounds and rears; using the C-50's at the closer listening distance. Another option might be to experiment with the Veritas centre as a single rear in a 6.1 configuration. Do a quick Audyssey run with each combination. While Audyssey can make all speakers sound exactly the same, it will do a reasonable job of creating EQ filters for all speakers to target a common in-room response. Any one of these options may work so well that you feel a surround/rear upgrade isn't ultimately necessary.
Welcome to AVS and good luck!
GIEGAR is offline
post #8 of 10 Old 07-18-2014, 10:37 AM - Thread Starter
Liked: 0
Thank you everyone for the input.
Quick question: I have an option to pick up Klipsch RF-82 II Reference Series 5.1 Home Theater without subwoofer for $1200 is this a good deal?
would the Klipsch be better option than Ascend Acoustics?
post #9 of 10 Old 07-18-2014, 11:02 AM
cel4145's Avatar
Liked: 2987
Not sure about whether that's a good deal. Considering they can be bought brand new with a sub (the sub is not as good as the Outlaws) for $1800, maybe not.
Klipsch have a different sound from the Ascends. Some people find that the Klipsch horns to be fatiguing at higher volumes. Given that, the Ascends can be the safer bet unless you can do some extended demoing of the Klipsch. But it really depends on you as to which you would like better.
cel4145 is offline
post #10 of 10 Old 07-18-2014, 03:50 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
My opinion of Klipsch is at the opposite end of the spectrum to Ascend Acoustics. I wouldn't buy products from a company that deliberately misleads consumers like Klipsch do. There's a couple of exhibits here:
Is it worth upgrading to floor standing speakers?
GIEGAR is offline
Reply Speakers
