in ceiling speakers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ack_bk
post #1 of 15 Old 07-17-2014, 11:33 AM - Thread Starter
mrkkk's Avatar
Arrow in ceiling speakers
total newbie
I saw in ceiling speakers at my friends place, he bought a new house and the builder put them for him
he has all speakers in the ceiling, one subwoofer lying around the side
I am looking at cheap option - Pyle PDIC80
tell me where to get started, what amp/wires/other things that I need to buy
how do pyle compare to polks etc
I have a single story house, these are for family living room, my tv is on the wall above fireplace, so not much place to put too much stuff there.
Another idea would be use to use newer wireless tech...
mrkkk is offline
post #2 of 15 Old 07-17-2014, 12:02 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
If you are trying to do this on the cheap, I would get these for your mains (note $159 is the price for a pair). They can sell you a third one for the center channel as well without having to buy a pair:
http://www.htd.com/Products/high-def...iling-speakers
Use these for surrounds and other speakers in the house:
http://www.htd.com/Products/multi-pu...iling-speakers
For a receiver, you just need something entry level.
http://www.amazon.com/Denon-AVR-E200...keywords=denon
I would get your speaker wire at Monoprice:
http://www.monoprice.com/Category?c_id=102&cp_id=10239
Maybe something like this for a subwoofer:
http://www.parts-express.com/dayton-...oofer--300-629
If you can share your budget and expectations we can help you better, but I was assuming you wanted to do this on the cheap.
ack_bk is offline
post #3 of 15 Old 07-17-2014, 02:40 PM
Quoted: 27 Post(s)
Liked: 1
Hi, I'm actually looking at doing the same thing. I've considered a range of speakers from the pricier Def Tech UIW RCS line, to the Polk RC80i to Micca R-8C... on the cheaper end of things, I've read that the Micca's are better than Polks or Monoprice. How would you say your HD-R65AIM recommendation compares to the Polk, Micca, or Monoprice? Also would you recommend them over Def Tech UIW 83/A?
I'll be using them primarily for music distribution on a floor of house, not for home theatre, so I don't need surrounds. Are angled speakers useful if there's no set focal point?
HawaiiR is offline
post #4 of 15 Old 07-17-2014, 02:41 PM - Thread Starter
mrkkk's Avatar
I may need to find an electrician to actually install these, I was hoping to do this cheap, still enjoy movies/songs
not an audiophile at all, only recently I started hearing existence of bass in the songs, haa
some indian music i listen to is low quality in terms of recording (old songs - sometimes as old as 50 yrs)
the room is not big, may be 20x20 ft
just two walls, other two are open, so wall speakers wont work, ceiling would be better
http://www.amazon.com/Pyle-PDIC80-In.../dp/B00069QMPC
These are super cheap and great reviews, so started from there
Product Features and Technical Details
Size: 8'' | Style: Standard
Product Features
In-Wall / In-Ceiling System - 2-Way Stereo Sound Speakers
Dual 8-inch Speakers - 4-8 Ohm impedance, 1.5-inch High Temperature Voice Coil
Directable 1-inch Titanium Dome Tweeter, 300 Watts Rated Peak Power
Mounts Flush on Walls or Ceilings, Perfect for Custom Installations & Applications
Overall Dimensions: 10 3/4 x 3 1/2 Inch, Cut-Out: 9 3/8 x 3 1/2 Inch
Technical Details
Brand Name: Pyle
Model: PDIC80
Color Name: White
Speaker Type: Ceiling; Wall-Mount
Speaker Amplification Type: Passive
Speakers Maximum Output Power: 300 Watts
Speaker Connectivity: Wired
Height: 9.5 inches
Weight: 1.9 Kilograms
Warranty: 1-year
I know 300 watt is peak, so it may be more like 150
I may not need a subwoofer right now, or I should be able to add it later right?
Just want decent/ok sound, reliable amp, nothing fancy
mrkkk is offline
post #5 of 15 Old 07-17-2014, 02:45 PM - Thread Starter
mrkkk's Avatar
and how would ceiling speakers system compare to those 200$ sound bars?
mrkkk is offline
post #6 of 15 Old 07-17-2014, 03:03 PM
Quoted: 27 Post(s)
Liked: 1
I'm doing some research into the same thing actually.
If I may offer my humble opinion, I'd like to suggest you steer away from Pyle. I've never heard good or decent sound coming out of anything from that brand.
If you wish to go the cheap route, I would recommend considering the MonoPrice line or Micca; polk if you can spend a few extra dollars.
There's a discussion about all three brands here:
Micca Reference series speakers price drop on Amazon
The monoprice ones (4104's I believe) are just barely more than the Pyle's you mentioned, and the Micca Reference R-8C are about $120 for a pair.
I'm actually thinking about getting a pair of the Micca speakers and some more expensive Definitive Tech DI8R speakers (unless someone convinces me otherwise).
Also, definitely consider purchasing a subwoofer. It's the only way you'll fill in the lower frequencies that the ceiling speakers definitely won't.
HawaiiR is offline
post #7 of 15 Old 07-17-2014, 04:04 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
I have not heard the Micca speakers, but I helped my next door neighbor install the HD-R65AIM speakers and they are good for the price. I would say better than the Polk's for sure.
If you can budget more money, I would definitely try to step into the UIW RCS line from Dedtech. They are a step above, and are fully enclosed which helps reduce sound bleeding into other walls and will be more dynamic speakers.
I can't speak to the UIW 83, but if I were going to spend more I would try to get the RCS speakers. Check Ebay, you can sometimes find them from reputable dealers for a good price.
This guy has good deals all the time on reconditioned Deftech speakers and I have purchased several speakers from him and they were in perfect condition:
http://www.ebay.com/itm/Definitive-T...item2c8246cd06
ack_bk is offline
post #8 of 15 Old 07-17-2014, 04:56 PM
Quoted: 27 Post(s)
Liked: 1
Hi thanks for your advice. I was actually looking at speakers from Bajawaverunner on Ebay.
The RCS line seem more directional though. Their tech (at deftech) actually mentioned that those aren't right for my application and suggested the DI8R, which I'm still considering. I will also give your recommendation a look, too. So many choices.....lol
HawaiiR is offline
post #9 of 15 Old 07-17-2014, 05:47 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
Are you using these speakers primarily for movies or music? Is your ceiling sloped at all?
ack_bk is offline
post #10 of 15 Old 07-17-2014, 06:17 PM
Quoted: 27 Post(s)
Liked: 1
I'm using them for music only. 2 in the living room area, 2 in the kitchen/dining, 2 in the studio/bedroom. And no the ceiling is not sloped.
HawaiiR is offline
post #11 of 15 Old 07-17-2014, 09:36 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
Ah, that explains it, I was thinking this was for home theater. Yes, you definitely don't want the UIW RCS series for that
ack_bk is offline
post #12 of 15 Old 07-18-2014, 02:16 AM
Quoted: 27 Post(s)
Liked: 1
Ha! Ok, the confusion was starting to set in for a second....lol.
HawaiiR is offline
post #13 of 15 Old 07-18-2014, 12:15 PM - Thread Starter
mrkkk's Avatar
mrkkk is offline
post #14 of 15 Old 07-18-2014, 12:20 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
For music these would work great. For home theater, I would not use them. For home theater you want something that is angled to direct the sound towards your listening position (couch/chair) and not to the floor in front of you. These speakers would be okay for surround spoeakers but the AIM65 speakers would be better for left, right, and center front speakers.
HawaiiR likes this.
ack_bk is offline
post #15 of 15 Old 07-19-2014, 11:38 PM
Quoted: 27 Post(s)
Liked: 1
Thanks for that link! I bought them for $75 each. Not a bad deal.
HawaiiR is offline
Reply Speakers
