New Theater Room - Need advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-18-2014, 09:57 AM - Thread Starter
Liked: 0
Question New Theater Room - Need advice
I have been researching and my brain is going absolutely crazy from choosing a home theater setup. I am looking to turn the basement family room (20'L x 8'H x 12'W) into a movie room. The family will mainly be watching movies and listening to music every so often (rarely).
I will be ceiling mounting a projector Sony VPL-HW40ES to display the picture on the 12' wall on a 130" screen with seating distance of 13'
My budget is ~$4000 for the projector, speakers, and receiver. ($2200 for speakers/receiver after taking out projector cost)
Looking for advice on the following:
1) 5.1, 5.2 or 7.1 with the room size?
2) Thinking of doing 1 now and 1 later for the sub(s) SVS PB-1000
3) Speakers
Fronts - ?
Center - ?
LR - ?
Rears (if 7.1) -
Side Note, I do have 8 HD-R65-ceiling-speakers I could use also for any of the speakers, but only if they would provide better sound.
mattus is offline
post #2 of 8 Old 07-18-2014, 11:47 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Are you handy at all? If so, for your budget you could do a killer DIY speaker and sub build that would be superior to anything you can buy for the money.
http://www.diysoundgroup.com/wavegui...aker-kits.html
All you have to do is just put everything together and wire it (crossovers are even built).
ack_bk is offline
post #3 of 8 Old 07-18-2014, 02:35 PM - Thread Starter
Liked: 0
What kits would you recommend I pick up from there for a 5.2 system? I am correct in thinking the room wouldn't work well with a 7.1, correct?
Just picked up the TASCAM - PAR200 - 7.2 CHANNEL SURROUND RECEIVER RS232 for 244.1/Shipped with a 3-Year SquareTrade Warranty
mattus is offline
post #4 of 8 Old 07-18-2014, 03:06 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You could make 7.x work, but I would just wire for it (if you have not already) and focus on 5.x.
Personally, I would approach building your HT system as more of a marathon than a spring and when you consider that your main speakers (front left, right, center and sub) do almost all the heavy lifting and are the most important speakers in the setup focus your budget there first and foremost.
I don't know if you have space restrictions for your mains but I would go with something like five of these based on your budget:
http://www.diysoundgroup.com/wavegui...sion8-kit.html
With the assembled crossover you are looking at around $200 a speaker to finish it (paint, roller, glue, etc). Five of them would be right around $1K. I would buy a $400 or so Denon receiver:
http://www.amazon.com/Denon-AVR-S700...keywords=denon
And that leaves you around $800 for a sub. If you go the DIY route you can get a flat pack from DIY Soundgroup:
http://www.diysoundgroup.com/sealed-...flat-pack.html
A woofer for the box:
http://www.parts-express.com/dayton-...4-ohm--295-469
Or the 15" D4 woofer from here:
http://stereointegrity.com/index.php?id=57#
And something like this to power it:
http://www.amazon.com/Behringer-NU10...keywords=inuke
Start with one, and the iNuke has enough juice to power another
In fact you probably have just about enough money to build two subs.
Then add two more speakers down the road for 7.2
ack_bk is offline
post #5 of 8 Old 07-18-2014, 04:19 PM
Kini62's Avatar
Quoted: 1424 Post(s)
Liked: 1319
Since you have some in ceiling speakers already I would look up how Atmos uses them and install them so you are ready when Atmos becomes more common.
I would also look to upping the sub budget (pre-built) or going with a pair of DIY models.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #6 of 8 Old 07-18-2014, 04:48 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
7.1 could work fine in your room. With a 20' room depth, and your seating at 13', you'd have 7' behind you for rear surrounds. They would "work" just fine. Having said that, at your pricepoint, I would recommend you focus on "better" 5.1. Wire now for the rears, but wait until the wallet refills to get them.
With a 12' room width, you'll want to place your side surrounds at 90 to 110 degrees to the seating. This puts them on the side walls. Lower profile speakers will likely work best in that placement. Keep that in mind as you look at speakers.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #7 of 8 Old 07-22-2014, 08:27 AM - Thread Starter
Liked: 0
Wife is hounding me now to look at in-wall/in-ceiling speakers (fighting it tooth and nail). Any suggestions on those? Budget is still the same and what disadvantage/downside(s) is there in-wall/in-ceiling speakers?
Also, what should I be looking for, in terms of an equipment rack?
Thank you for all your help, really appreciate the community here.
mattus is offline
post #8 of 8 Old 08-12-2014, 10:11 PM - Thread Starter
Liked: 0
How would this setup rate for sound?
Left/Right - Pioneer SP-FS52-LR Andrew Jones Designed Floor standing Loudspeaker
Center - Pioneer SP-C22 Andrew Jones Designed Center Channel Speaker
Surronds - Pioneer SP-BS22-LR Andrew Jones Designed Bookshelf Loudspeakers
Sub - Dayton Audio RSS390HO-4 15" Reference HO Subwoofer 4 Ohm
Also, If I were to go with In-Ceiling Speakers, what would you recommend?
mattus is offline
Reply Speakers
