$1000 for Front Sound Stage - is reference possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-18-2014, 11:18 AM - Thread Starter
jerrolds's Avatar
Quoted: 32 Post(s)
I'm only familiar with the Energy Veritas sound, other than that its my "mid fi" Hifiman HE400 Planar headsets.
Space is a basement, specifically one wing of it - about 12x11x8 feet in dimension where one side opens up to the rest of this T-shaped basement. http://imgur.com/qIsjapY
I already have an SVS PB-1000 for a sub and 2 Energy mini veritas as the side surrounds. What would be the best option for a movie like sound. I'm thinking that adding a 2nd PB-1000 is a possibility.
JBL, Def Tech, HTD, hit me with what you like for $800-1000USD Id rather stay to the $800-900USD range since im in Canada - but i can definately order from Amazon.com and drive a couple hours to the border for pickup.
"Reference" might not be possible, as my receiver can only output up to 50w through 7 channels (8ohm 0.07% THD) - so i guess high efficiency speakers would be nice.
I have time, maybe a few months at least - i wonder if Atmos is best in this situation.
jerrolds is offline
post #2 of 16 Old 07-18-2014, 11:58 AM - Thread Starter
jerrolds's Avatar
Quoted: 32 Post(s)
Buying used is definitely an option as well. My 5 speaker energy vminis and pb1000 were all used and function great.
jerrolds is offline
post #3 of 16 Old 07-18-2014, 12:09 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Sounds to me like you are looking for high senstivity, high SPL speakers. Lots of threads on it. If you are not afraid to assemble some kits and paint them this can easily be done for under $1K.
http://www.diysoundgroup.com/wavegui...-pure-kit.html
You can buy the assmebled crossovers for a little over $20 apiece. Some Duratex, a couple foam rollers, and you would have high SPL speakers for under $800 to your door.
ack_bk is offline
post #4 of 16 Old 07-18-2014, 01:03 PM - Thread Starter
jerrolds's Avatar
Quoted: 32 Post(s)
Oh cool - 10" woofer? Thats immense - would that out perform something like Klipsch RF-82? I actually do have a bit of experience with mdf/painting to a glossy finish (pain in the ass) when i made my Vewlix Arcade Clone last year
Its not a pretty speaker, I do like the look of the Veritas/RF (cooper) line. Lets see what the gf thinks heh
Yes i guess High SPL speakers would be best, but i would like to have a cinema like sound if possible
Thanks again!
jerrolds is offline
post #5 of 16 Old 07-18-2014, 01:08 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Outstanding choice of headphones, if I do say so myself.
FMW is offline
post #6 of 16 Old 07-18-2014, 01:10 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Thanks again!
The waveguide speakers I linked to, IMHO, are a nice jump over the Klipsch RF82. There are lots of guys that have really nice home theaters using those waveguide kits who come from expensive speakers and love them. They are perfect for home theater/cinema sound. I wish I would have gone this route, but they were not available when I built my home theater. I did sell my expensive Hsu sub and built 4 DIY subs for the same price and it was a noticeable improvement.
ack_bk is offline
post #7 of 16 Old 07-18-2014, 01:12 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Most of the SEOS waveguide options on diysoundgroup will easily get you to reference, and they all sound great.
Bassment is offline
post #8 of 16 Old 07-18-2014, 03:08 PM - Thread Starter
jerrolds's Avatar
Quoted: 32 Post(s)
If i did not want to go the DIY route - what other options do i have at the $800-$1000USD range for the front sound stage?
jerrolds is offline
post #9 of 16 Old 07-18-2014, 03:34 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1221
The top of this page shows the best sub US$1000 front end that I'm aware of: http://www.ascendacoustics.com
GIEGAR is offline
post #10 of 16 Old 07-18-2014, 04:15 PM
Kini62's Avatar
Quoted: 1425 Post(s)
Liked: 1319
If you can up your budget a little, these should get you close to you goal
http://www.chanemusiccinema.com/chan...rs/Theater-Ten
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #11 of 16 Old 07-18-2014, 05:34 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
He has a 50w receiver and wants high clean high SPL to hit reference. I don't think this combo will get it done. Don't get me wrong, I like Ascend, but the Chane option is probably a better one if he wants a finished product.
Klipsch is another option.
ack_bk is offline
post #12 of 16 Old 07-18-2014, 07:12 PM - Thread Starter
jerrolds's Avatar
Quoted: 32 Post(s)
Thanks theyre pretty fantastic - tight punchy bass while keeping the mids and highs clear. Some sibilance though - but eq fixes it. I did a grill mod and waiting on the 560 pads to come in to replace my velour. Got them used for $250CAD last year, its what started the audiophile journey
jerrolds is offline
post #13 of 16 Old 07-18-2014, 07:15 PM - Thread Starter
jerrolds's Avatar
Quoted: 32 Post(s)
Yea its currently what i have - but i have no problems replacing it shortly after. I keep scouring the classified for good deals on amps, since the receiver has pre-outs which is nice. Might not be able to hit reference cleanly with this AVR but i think itll get to a decent level in the basement.
Right now i think the upgrade path will be
1. veritas mini front sound stage (current)
2. $1000 for Left/Right/Center - more body, more cinema like
3. 2nd PB-1000 or possibly DIY 15"+ sub
4. Amp or new AVR (atmos perhaps)
jerrolds is offline
post #14 of 16 Old 07-18-2014, 08:53 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
del
coli is offline
post #15 of 16 Old 07-18-2014, 09:14 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 142
Those Ascend 340s are pretty sensitive. I don't see a problem.
http://www.ascendacoustics.com/pages...340mspecs.html
Gmash is offline
post #16 of 16 Old 07-21-2014, 06:45 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
Reply Speakers
