Better speakers or better placement/spacing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-18-2014, 01:39 PM - Thread Starter
Liked: 0
5.1 system used for movies and hopefully gaming again in the not to distant future (two young kids have caused a hiatus)
I currently have Athena B1s for left and right, Athena C1 for center, Athena 10" sub and crappy rears that are getting replaced regardless
We just bought a new entertainment center in which I haven't figured out what to do with my center speaker (since I no longer have a center shelf for it).
I have a large doorway to the left of my TV limiting my ability to spread my speakers apart unless I go above, which I don't want to do with bookshelf speakers because I think it will look bad. Left and right speakers are only about 5 ft apart. I sit about 11 ft back so they should be about 11 ft apart.
My budget is tight too. <$300
Is it better to keep what I have how I have it, which is nicer speakers, at non-optimum placement. (I might mount the center on a shelf above the TV)
Or buy some cheaper speakers, like the Monoprice premium 5.1 or some in ceilings even (my ceiling above the TV is angled perfectly downward toward the couch) and have them at optimum distance apart (albeit higher than ear level)
It might be worth mentioning I have a Denon e300 with Audyssey.
Solution needs to look good for WAF.
ChucksInCharge is offline
post #2 of 14 Old 07-19-2014, 01:03 AM
SmithandWesson's Avatar
Liked: 41
I wouldnt go with in celling speakers, they seriously compromise sound quality in exchange for the ultimate WAF.
Your going to be pretty limited as far as the L&R channel go since those speakers look pretty narrow and are already flush with the TV and sides of the entertainment center.
As far as the center goes, you could always just save money and not get one. I use to have a 7.2 system in a dedicated HT and now have a HT in another room but I only have 2 large towers and 2 large subs. Honestly i dont miss my center channel that much. So long as you get decent L&R channels they will produce a phantom center. When I demo my system to people they proclaim at how good my "TV speakers" sound, they are surprised to learn that my TV speakers arent on, all that center sound is coming from my L&R channels.
Main System: SVS Ultra Towers - 15" custom ported subwoofer - SVS PB-1000 - Yamaha RX-A740 Aventage. 122dB @ 16Hz!!!
Computer System: Carnagie Acoustics CSB-1 - 12' Onkyo sealed subwoofer - Pioneer VSX-92 THX
Other speakers owned or auditioned: Aperion T6 - Ascend CBM-170 - Energy RC-10 - Wharfdale 10.1 - Arx A1b
SmithandWesson is offline
post #3 of 14 Old 07-19-2014, 09:22 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
What sub is that? Might be best to invest your money in a sub upgrade.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #4 of 14 Old 07-19-2014, 09:43 PM
NuSoardGraphite's Avatar
Quoted: 326 Post(s)
Liked: 298
Is it in any way possible to move the TV/Speakers to a different wall to spread them apart better? Setup is paramount, so it's always better to improve your setup and see if that improves your sound quality before buying better speakers.
I feel your pain. I'm in a similar position. About 11 feet away from my TV but L/R speakers are only 6' apart Nothing I can really do about it. When my HT was in a different room (different house) I was 10' away from the tv with the speakers 10' apart. The stereo separation of the main speakers was tangible. I really miss it.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #5 of 14 Old 07-20-2014, 12:01 PM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
I'd move the console and tv to the center of the wall (between the opening and the side wall). Get some stands (or articulating wall mounts, if you are worried about kids) and put each speaker about centered between the (wall/console, opening/console) Get the tweeters at ear level and experiment with forward and side positioning a bit. If you can get a nice image at your seat, you won't need to use the center. if you can't, the center should sit at the very front of the console to reduce reflections.
Use stacks of books as temp stands to experiment with height and placement. Best sound will be had by having the front of the soeakers in front of the console.
RayGuy is offline
post #6 of 14 Old 07-20-2014, 04:01 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Based on where you speakers are now you don't need to use the center speaker. Just set the center to NONE and let the front speakers handle the dialog.
You should pull the B1's to the front of the cabinet to reduce sound reflections. Or ultimately move the console to the right a foot or so to allow for speaker stands.
Satellite speakers and in ceiling speakers would be a downgrade. Don't go there.
Afro GT
afrogt is online now
post #7 of 14 Old 07-20-2014, 04:59 PM - Thread Starter
Liked: 0
The sub is the Athena AS-P400.
No. They have to stay on that wall.
I might be able to move the entertainment center a foot to the right.
post #8 of 14 Old 07-20-2014, 06:52 PM
cel4145's Avatar
Liked: 2985
Those appear to be pretty decent subs. Probably have to spend a good bit to improve upon it.
post #9 of 14 Old 07-21-2014, 01:51 PM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
Why only a foot?
RayGuy is offline
post #10 of 14 Old 07-21-2014, 03:46 PM
89grand's Avatar
Quoted: 288 Post(s)
Liked: 163
That setup would benefit greatly from better speaker placement, but without knowing what the rest of the room looks like, I have no idea what would work better since I can't tell what you can or can't do in there.
89grand is offline
post #11 of 14 Old 07-21-2014, 08:48 PM - Thread Starter
Liked: 0
Originally Posted by RayGuy View Post
Why only a foot?
Because of the love seat in front of the window.
And the second picture shows the rears. One is behind the picture on the mantle facing toward the couch.
Maybe this gives a better idea of the room.
ID:	173929   Click image for larger version
post #12 of 14 Old 07-21-2014, 08:57 PM
cel4145's Avatar
Liked: 2985
You just need to buy new furniture to accommodate your stereo
post #13 of 14 Old 07-22-2014, 12:30 AM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
Put the love seat on the wall that currently has the tv. Move the couch into the position in front of the window vacated by the love seat. Then move the console, tv and speakers to the long wall opposite the love seat, vacated by the couch.
RayGuy is offline
post #14 of 14 Old 07-22-2014, 07:46 AM
jedimastergrant's Avatar
Quoted: 545 Post(s)
Liked: 269
I think others have given good advice. You will see the most benefit from optimizing placement of speakers and listening position. Unless you are spending loads of money on super nice in ceiling speakers I don't think it would be an upgrade. Especially with the monoprice stuff.
If you can't convince your wife to let you change the placement in the room then you will always be limiting the system. Is there another room in the house you could move it to? Just do the best you can.
And you can probably just take out the center as has been suggested.
Don't know what your surrounds are but you might be better served to put the money into a better sub instead. In ceiling surrounds can be a good option if placed and directed appropriately.
jedimastergrant is online now
Reply Speakers
