Which Speakers should I Refresh in my home theater? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-19-2014, 05:33 PM - Thread Starter
Jerryco's Avatar
Hi Folks,
I been using following speakers for my home cinema for a while now.
I saved some cash and thinking to upgrade per need. I would appreciate your recommendation:
What will you upgrade to make it better.
I have $1000 to spare for upgrade.
Currently owned 7.1 system:
Center -JBL EC25
Front - JBL L880
4 Rear - JBL Venue Series -TOUR
Sub - SAS SB12
Receiver - Yamaha RX-V673
Appreciate your feedback
Jerry
Jerryco is offline
post #2 of 5 Old 07-19-2014, 05:40 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
I would upgrade the sub. I wouldn't bother upgrading the mains until you have saved more money. $1k isn't going to get you a serious upgrade over anything you have now for the front stage, but it can get you a subwoofer like a Hsu VTF15h or Reaction PV 15X, either of which will be many times better than the subwoofer you have now.
shadyJ is offline
post #3 of 5 Old 07-19-2014, 05:46 PM
zieglj01's Avatar
Quoted: 1562 Post(s)
Liked: 1411
I would get a L series center channel to match the fronts
http://www.amazon.com/JBL-Performanc...channel&dpPl=1
And, a new subwoofer
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 5 Old 07-19-2014, 06:13 PM
dsrussell's Avatar
Quoted: 2258 Post(s)
Liked: 3088
Jerryco: Did you mean the SVS SB12? Never heard of SAS (except for the airline ... and British special forces). If you meant SVS SB12 nsd, then I don't see the great need to upgrade the subwoofer unless your room volume is well over 1,500 cu.ft., then a ported sub may serve you better.
dsrussell is offline
post #5 of 5 Old 07-19-2014, 08:46 PM - Thread Starter
Jerryco's Avatar
Yes you are right I have sb12 - SVS Sub, I bought per recommendation from this forum.
I think I should upgrade my Center.
Jerryco is offline
Reply Speakers
