I am dense: How do I remove this mount? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ifor
post #1 of 4 Old 07-20-2014, 09:10 AM - Thread Starter
pizzaboy's Avatar
I want to mount these on the wall... Cannot figure out how to detach the mount from the speaker (the screws cannot be screwed into wall while mount is attached to speaker...)...
Help a brother out... LOL...
pizzaboy is offline
post #2 of 4 Old 07-20-2014, 11:53 AM
ifor's Avatar
Quoted: 64 Post(s)
Liked: 72
There is a long hex tool needed. You need a 6mm by at least 4" long.
It enters from the front the speaker through a hole in the grill which is located behind the logo.
It loosens until the ball on the bracket lets go.
darthray likes this.
ifor is offline
post #3 of 4 Old 07-20-2014, 07:41 PM
darthray's Avatar
Quoted: 1159 Post(s)
Liked: 1062
Glad you could help the OP, I would never have figure this one out!
And by the way, HOLLY MOLLY that is a nice set-up you got!
Nice finish to the room and lots of electronics
Ray
darthray is offline
post #4 of 4 Old 08-03-2014, 09:30 AM - Thread Starter
pizzaboy's Avatar
Thanks! Exactly what I needed!
pizzaboy is offline
Reply Speakers
