High-End Audio Racks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-10-2002, 11:49 AM - Thread Starter
DreamCatcher's Avatar
Hi,
I'm looking to get a really cool audio rack.
Something that's sturdy enough to hold heavy amps.
Something that can hold or expand to accomadate two big amps and around 8 other components.
Shelves that are deep around 20"......................
Any ideas/suggestions?
dc
StayThristyMyFriends
DreamCatcher is offline
post #2 of 13 Old 08-10-2002, 11:56 AM
Julian Rinaldi's Avatar
Once I finish buying all of my equipment I will buy my audio racks from www.salamanderdesigns.com. You can mix annd match to get exactly what you need, and they have different styles and finishes. Shelves are 19.75" deep, so almost 20". You wouldn't go wrong with those.
-Julian
Julian Rinaldi is offline
post #3 of 13 Old 08-10-2002, 12:52 PM
mbpg's Avatar
Hello dc
Billy Bags aren't inexpensive but they have a first class reputation, look very nice and set the standard for sturdy. Look here http://www.billybags.com/index2.html
Regards, Michael
mbpg is offline
post #4 of 13 Old 08-10-2002, 03:32 PM
RichardMA's Avatar
Power amps should be on the ground on marble plates. :)
"If Blockbuster continues to offer ONLY Pan & Scan versions of major movies as rentals instead of correct aspect ratio (widescreen) versions,
please do not rent DVDs from them."
RichardMA is offline
post #5 of 13 Old 08-11-2002, 02:28 AM
Thomas F's Avatar
Take a look at the Lovan Millennium. It's designed to hold components up to 150 lbs and the glass shelves are quite large. It's modular and you can mix and match the various sizes to fit your needs. I have one and IMO, it is really quite attractive, albeit, a little pricey.
Thomas
Thomas F is offline
post #6 of 13 Old 08-11-2002, 07:25 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
I chose to go to a local unfinished furniture and have a cabinet custom built to my specs. Shelves are 24 inches deep. My amp is 25 inches deep so it sticks out the back a little. The cabinet is made of Birch and was stained to match my speakers. I decided to go this route after inspecting several racks and feeling I was being "ripped off" for the price asked at the level of quality being offered. Many are flimsy, not deep enough, and the boards used for the racks didn't appear to be sturdy enough to hold some of my heavier gear. Expanding would involve me deciding on what additional space I needed and contacting the store which would then custom build the other piece and stain it to match as well.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #7 of 13 Old 08-11-2002, 07:35 AM
LCSeminole's Avatar
Quoted: 38 Post(s)
Liked: 31
Try looking at Sanus Systems, very solid steel frames, extremely modern looking. www.sanus.com
Emotiva XMC-1/XPR-2/XPR-5/DC-1
Panasonic TC-P60ST60, Oppo UDP-203, Amazon Fire TV
Furman PL-PRO DMC 20A, Monster Power HTS-5000
SVS PB12-Plus DSP x 2
Klipsch KLF-20 & KLF-C7(Crites Tweeter/Midrange Diaphragms & Crossovers)
Emotiva ERM-6.2(Side/Rear Surrounds)
LCSeminole is offline
post #8 of 13 Old 08-11-2002, 07:51 AM
mfombellida's Avatar
Another one:
http://www.schroers.de/einleitung/en...duction_e.html
I have the Focus 72 Maxi.
and also
http://www.finite-elemente.de
Michel
mfombellida is offline
post #9 of 13 Old 08-11-2002, 08:20 AM
Mozvz's Avatar
Boltz may be another option.
http://www.boltz.com/
also:
http://www.avrak.com/main/main.html
"Man plans, God laughs"
Mozvz is offline
post #10 of 13 Old 08-11-2002, 04:11 PM
Topanga's Avatar
For pure sound quality try www.zoethecus.com and www.symposiumacoustics.com. For good looks and much stronger than most racks with adjustable shelves and a door try www.studiotech.com. the Studiotechs have internal steel bracing.
Rick
Topanga is offline
post #11 of 13 Old 08-11-2002, 04:41 PM
amillians's Avatar
Is any of your equipment rack mountable (e.g., has ears)? If so, it's hard to beat Middle Atlantic racks...but I'm not sure that's what you're after (they look best built into a wall/partition). If you want something that looks like furniture, then disregard this suggestion! :)
Alex doesn't live here anymore
amillians is offline
post #12 of 13 Old 08-11-2002, 05:31 PM
botrytis's Avatar
I will second Julian's Recommendation of Salamander Design. I just put up a rack and it is beautiful!! I bought in cherry and black - looks fantastic!!
Dave
"If A equals success, then the formula is A equals X plus Y and Z, with X being work, Y play, and Z keeping your mouth shut." - Albert Einstein
botrytis is offline
post #13 of 13 Old 08-12-2002, 12:25 AM
AlanHsu's Avatar
How about the Symposium Precision Rack? See http://www.symposiumusa.com/rack.html
Steve should try them out since he's got so many Symposium isolation platforms.
Alan Hsu
AlanHsu is offline
Closed Thread Speakers
