infinity primus p363 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2014, 07:09 PM - Thread Starter
Bretzy1990's Avatar
I see infinity p363 is in stock and on sale on amazon for 107 each. I currently have klipsch f-30 front tower speakers and am looking for 2 surround speakers and was wondering if the infinity primus p363 would be a viable option for my surround speakers? They handle alot of power and IV been told for the money their hard to beat. I know that klipsch is a horn speaker so I'm not entirely sure if the system would blend well.
Bretzy1990 is offline
post #2 of 5 Old 07-20-2014, 07:43 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
It isn't as critical for surrounds to match, but you don't want to mix different speakers in the front stage. I think Infinitys would make good surrounds, depending on the circumstances. Many surround setups benefit from being elevated, especially if you have high backed seating. If you don't, I think ear level tower speakers can work as surrounds.
shadyJ is offline
post #3 of 5 Old 07-20-2014, 07:53 PM - Thread Starter
Bretzy1990's Avatar
as far as furniture just an l couch. I do listen to music. I wonder how it would sound in a stereo mode
post #4 of 5 Old 07-21-2014, 02:30 AM
shadyJ's Avatar
Liked: 1350
Since you are using them a surrounds, it looks like it wouldn't matter how they sound in stereo mode. For the best two channel music playback, just use the front two, with subs maybe. Anyway, the p363 are overkill for surrounds, but since they are so cheap, there is no reason not to try it to see if it works for you. At the present prices its almost disposable, so its definitely worth a try, in my opinion. Shipping them is probably more expensive then the speakers themselves.
shadyJ is offline
post #5 of 5 Old 07-21-2014, 08:36 AM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
you might even like them more than the F30.
Afro GT
afrogt is offline
Reply Speakers
