Cleaning Kevlar speaker woofer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-22-2014, 02:25 PM - Thread Starter
t1337Dude's Avatar
Quoted: 173 Post(s)
Liked: 117
On one my 8" Kevlar woofers, there are two transparent but somewhat visible spots (a small splash of something that wasn't water?). When viewing the speakers in the reflection of light I find it distracting. Can I use a slightly moist towel or rubbing-alcohol soaked cotton swab to erase the spots? I'd be applying as little liquid as possible on the Kevlar because I'm just trying to do minor spot cleaning - would it still be unsafe to do so?
t1337Dude is offline
post #2 of 3 Old 07-22-2014, 07:01 PM
charmerci's Avatar
Quoted: 316 Post(s)
Liked: 204
They make bullet-proof vests with Kevlar.....
charmerci is offline
post #3 of 3 Old 07-23-2014, 12:32 PM
SmithandWesson's Avatar
Liked: 41
Kevlar is fairly chemical resistant so you should be fine. Try using water first, if not diluted alcohol should be fine.
There's no such thing as bullet proof vests. The proper term is bullet resistant or ballistic vest. Virtually any rifle round will zip right through both sides of a Kevlar vest. Even if a handgun round doesn't penetrate the Kevlar you can still die from back-face deformation.
Main System: SVS Ultra Towers - 15" custom ported subwoofer - SVS PB-1000 - Yamaha RX-A740 Aventage. 122dB @ 16Hz!!!
Computer System: Carnagie Acoustics CSB-1 - 12' Onkyo sealed subwoofer - Pioneer VSX-92 THX
Other speakers owned or auditioned: Aperion T6 - Ascend CBM-170 - Energy RC-10 - Wharfdale 10.1 - Arx A1b
SmithandWesson is offline
Reply Speakers
