I've got a problem I need help with - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By 89grand
post #1 of 7 Old 07-23-2014, 10:32 AM - Thread Starter
Liked: 0
Hi all. Hope this is Somthing I can get help with. I have a Mitsubishi xd206u. I wanna hook my xbox 360 up to it using the yellow video cable as this is the only way to hook it up.. Now I need sound.. The projector has 2 3.5mm audio jacks one is labeled audio in and the other audio out. What cable would I need to hook up RCA from my xbkx into the projector so the audio out I can connect my 5.1 conputer speakers? Thanks in advanced
Smurphster is offline
post #2 of 7 Old 07-23-2014, 10:40 AM
89grand's Avatar
Quoted: 288 Post(s)
Liked: 163
You'd need a 3.5mm to RCA cable, they are very common, I have several. Monoprice is a good place to get one.
89grand is offline
post #3 of 7 Old 07-23-2014, 10:47 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
If you are trying to get the video from the Xbox to the projector, and the audio from the Xbox to the computer speakers, then you need to connect the Xbox to your computer speakers. How do you connect your speakers to the PC?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #4 of 7 Old 07-23-2014, 10:48 AM - Thread Starter
Liked: 0
I'm going threw the projector so I just need a way to connect the RCA to a aux in the projector then plug my speakes in
post #5 of 7 Old 07-23-2014, 10:49 AM - Thread Starter
Liked: 0
It's like the but the RCA from the xbox would plug into that so the oppose of the RCA on that cable e
post #6 of 7 Old 07-23-2014, 11:01 AM
Liked: 1319
Just look for that cable with female RCA connections. www.monoprice.com has everything you could need.
post #7 of 7 Old 07-23-2014, 11:32 AM
89grand's Avatar
Quoted: 288 Post(s)
Liked: 163
And while your shopping on Monoprice, just pick up some other random cables you may need in the future. May as well just pay shipping once, and have some random cables on hand for the future. I have a whole bag full of y-adapters, various lengths of RCA cables, HDMI, USB to mini and mico, etc.
Transmaniacon likes this.
89grand is offline
Reply Speakers
