Polk TSi300 - TSx150C or CS10 Center - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-25-2014, 09:22 PM - Thread Starter
Liked: 0
I am planning to purchase Polk TSi300 speakers for front L & R of my 7 channel home theater system. Was thinking about the TSx150C center speaker, but reading the CS10 may be a better "match". Is the TSx150C worth the extra $100 ?
sjsherratt is offline
post #2 of 6 Old 07-26-2014, 02:23 AM
afrogt's Avatar
Quoted: 798 Post(s)
Liked: 632
No I don't think it's worth it..
The CS1, CS10, Monitor 15C and Tsx150 are essentially the same speaker in different cabinets. The CS1 is the oldest model and TSi150 the newest.
Afro GT
afrogt is offline
post #3 of 6 Old 07-26-2014, 03:35 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 799
me preference would be to get the one that matches your mains. if you have the tsi300's, go with the cs10 or cs20 center. if for no other reason, it will match aesthetically.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #4 of 6 Old 07-26-2014, 07:24 AM
commsysman's Avatar
Quoted: 830 Post(s)
Liked: 477
IMO the CS10 is not a very good speaker.
You would be well-advised to get a better one.
The TSX150C is $178 from Amazon,so the extra cost only seems to be about $70.
commsysman is offline
post #5 of 6 Old 07-27-2014, 11:36 PM - Thread Starter
Liked: 0
Thanks all - I really appreciate your input. No decision yet, but you have helped me.
post #6 of 6 Old 07-28-2014, 06:45 AM
crazyrob425's Avatar
Quoted: 442 Post(s)
Liked: 334
The CS10 is the matching center and is better on all fronts than the CS1.
The TSx150c is for TSx Series. Being that Polk's TSx series mellowed out some of the brightness compared to the TSi I would go with matching center, the CS10.
You can get manufacturer refurbished CS10's from Polk's ebay store for $90 shipped
http://www.ebay.com/itm/Polk-Audio-C...item540970b552
crazyrob425 is offline
Reply Speakers
