I want to get surround sound but don't know what to get - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-26-2014, 01:31 AM - Thread Starter
Liked: 0
I want to get surround sound but don't know what to get, as i have a projector in my bedroom above my bed, i think would need wireless speakers but the subwoofer would be behind me, wold that matter or is there a way to not have it wired to the projector?
thanks
bjf1999 is offline
post #2 of 8 Old 07-26-2014, 01:33 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Budget?
Have a look here what fits your speaker budget then see what AVR options you get
http://www.creative-audio.co.uk/CATLIST.php?CAT=HCSPEAK
fatbottom is offline
post #3 of 8 Old 07-26-2014, 02:00 AM - Thread Starter
Liked: 0
hi,
my budget would be around £600
i was looking at the
Denon AVR-X2000 7.1 network receiver
and the
Tannoy HTS 101 5.1 speakers
would the front speakers be wireless or have to be hooked up to the receiver on not
I was also wondering if tallboy speakers are any good?
thanks
bjf1999 is offline
post #4 of 8 Old 07-26-2014, 02:05 AM - Thread Starter
Liked: 0
Originally Posted by fatbottom View Post
Budget?
hi,
and the
thanks
bjf1999 is offline
post #5 of 8 Old 07-26-2014, 02:45 AM
fatbottom's Avatar
Liked: 519
Even if they're wireless they would need a power cable (active) I'd give up the idea of wireless speakers.
I do rate the Q Acoustics speakers highly but those are higher budget
post #6 of 8 Old 07-26-2014, 03:40 AM - Thread Starter
Liked: 0
Okay i will have a look at them more, i didn't really mean no power cable, i meant would there have to be a wire connecting the front seekers to the subwoofer or receiver at the back?
thanks again
bjf1999 is offline
post #7 of 8 Old 07-26-2014, 03:45 AM
fatbottom's Avatar
Liked: 519
Yes. It's not magic.
If they're active they'll need a power cable, and you might be able to transmit wirelessly.
If they're passive, they won't have a power cable but you'd need speaker cable to the speaker, and RCA to the sub. Some subs are wireless (audio) but need the power cable.
Give up your idea of wireless speakers.
post #8 of 8 Old 07-26-2014, 03:50 AM - Thread Starter
Liked: 0
okay thanks
bjf1999 is offline
Reply Speakers
