Energy Take classic... Paired with old marantz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-26-2014, 09:07 AM - Thread Starter
Liked: 0
Energy Take classic... Paired with older marantz
Hey guys - long time lurker - finally have a question I would love the knowledgeable community here to answer !
I have inherited a Marantz 7300ose receiver and am going to put a small 5.1 setup together in the basement. I have heard and read great things about the energy take classic speaker package - my question is (aside from the ohms being ok) is if this combo would prove too much power for the energy speakers. That said - is the receiver up to the task? Has component but no hdmi.
Also open to any other speaker packages as suggestions. With a kid on the way, am trying to do this on a budget!
Thanks all - appreciate the help!
Mfparkinson is offline
post #2 of 13 Old 07-26-2014, 10:13 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 759
Only if you turn it up too loud. Marantz 7300ose is a very capable receiver. Is there a reason why you need such small speakers like the Takes? Bookshelf speakers would be better than satellites.
If you have a budget how much is it?
Afro GT
afrogt is online now
post #3 of 13 Old 07-26-2014, 10:37 AM - Thread Starter
Liked: 0
Thanks Afro - was going with the Takes for the surround package... vs. building piece-by-piece at this time...
Looking to spend roughly $500...
I actually also have access to some paradigm bookshelf speakers...
post #4 of 13 Old 07-26-2014, 10:45 AM
afrogt's Avatar
Liked: 759
I would take Paradigm bookshelf speakers over Take Classics.
Which Paradigms?
Afro GT
post #5 of 13 Old 07-26-2014, 10:53 AM
afrogt's Avatar
Liked: 759
This subwoofer and your Paradigms would make a nice setup.
http://www.amazon.com/NXG-Technology...=nxg+subwoofer
Afro GT
post #6 of 13 Old 07-26-2014, 11:06 AM - Thread Starter
Liked: 0
And go 2.1 at higher quality vs 5.1 with the takes?
post #7 of 13 Old 07-26-2014, 11:12 AM
afrogt's Avatar
Liked: 759
yep, I would.
Or get that sub and 4 Infinity P153's. Nice 4.1 setup under $500.
Name:	Infinity P153 sale.PNG
Afro GT
post #8 of 13 Old 07-26-2014, 11:28 AM - Thread Starter
Liked: 0
Thanks Afro - really appreciate it. Then add a centre when budget allows?
post #9 of 13 Old 07-26-2014, 11:36 AM
afrogt's Avatar
Liked: 759
there ya go...
Or buy a 5th P153 and place it horizontally if you don't space to use it upright as a center.
Afro GT
post #10 of 13 Old 07-26-2014, 11:41 AM - Thread Starter
Liked: 0
Can I grab 3 infinity and use the paradigms as well? Or is mixing the brands not ideal?
post #11 of 13 Old 07-26-2014, 12:07 PM - Thread Starter
Liked: 0
Oh and one last question (again, really appreciate the help) - but being in Canada, I can't seem to find the p153's nor the sub... any comparable suggestions by chance?
post #12 of 13 Old 07-26-2014, 01:19 PM
afrogt's Avatar
Liked: 759
Do you live close to a border city? If so have them shipped via Kinek, then drive over the border and pick them up.
https://www.kinek.com/
You never mentioned you were in Canada until now. Maybe you should put that in your profile? Kind of a key point to leave out...
Yes, you could use the Paradigms as surrounds. Your front 3 speakers should match though.
Afro GT
post #13 of 13 Old 07-26-2014, 03:37 PM - Thread Starter
Liked: 0
Ha - very good point. Sorry! An in Toronto. But will look into it for sure.
Again, thanks for the help!
Reply Speakers
