Which cables are best for my Jamo speakers? - AVS Forum | Home Theater Discussions And Reviews
 145Likes
post #1 of 227 Old 07-27-2014, 08:11 AM - Thread Starter
arjunshriram's Avatar
Quoted: 129 Post(s)
I need advice on the issue described above. My receiver is a Denon 4810 and my speakers are the Jamo D7 Series.
arjunshriram is offline
post #2 of 227 Old 07-27-2014, 08:23 AM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
Any copper wire from your local hardware store. 12 or 14 ga is sufficient for most any application.
ls1115, sage11x, jaeelarr and 1 others like this.
MUDCAT45 is online now
post #3 of 227 Old 07-27-2014, 08:26 AM - Thread Starter
Quoted: 129 Post(s)
On D7's??
post #4 of 227 Old 07-27-2014, 08:36 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Originally Posted by arjunshriram View Post
On D7's??
On any speaker.
ls1115, sage11x and jaeelarr like this.
rick240 is offline
post #5 of 227 Old 07-27-2014, 08:45 AM - Thread Starter
Quoted: 129 Post(s)
Originally Posted by rick240 View Post
On any speaker.
Even ones costing S9K and above?
post #6 of 227 Old 07-27-2014, 08:50 AM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
On D7's??
What makes them different than any other speaker?
ls1115 and jaeelarr like this.
post #7 of 227 Old 07-27-2014, 08:52 AM - Thread Starter
Quoted: 129 Post(s)
THX Ultra 2 ??
post #8 of 227 Old 07-27-2014, 08:55 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
As long as you have sufficient gauge for your distance then any speaker wire (from simple stuff from Monoprice or Blue Jeans or hardware store to the most expensive) will transport the signal from your amp to the speakers with equal efficiency and in a blind test you would never be able to pick any difference.
If you like pretty cable, then either buy expensive ones or buy inexpensive ones and put on your own cable jackets.
jaeelarr and kpotier16 like this.
rick240 is offline
post #9 of 227 Old 07-27-2014, 08:55 AM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
THX Ultra 2 ??
Still uncertain how wire matters since it has no effect on THX or speaker cost.
I use it on more expensive speakers than the Jamo.
jaeelarr likes this.
post #10 of 227 Old 07-27-2014, 08:57 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
THX Ultra 2 ??
All speakers require the signal in their frequency range to be transported on the cable unadulterated (i.e. no cable should add or subtract anything).
All copper cables of sufficient gauge will do this.
rick240 is offline
post #11 of 227 Old 07-27-2014, 10:31 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
They are rated at 4-ohms nominal, so go a bit larger diameter (i.e. 12 AWG instead of 14 AWG).
psgcdn is offline
post #12 of 227 Old 07-27-2014, 12:59 PM
89grand's Avatar
Quoted: 288 Post(s)
Liked: 163
89grand is offline
post #13 of 227 Old 07-27-2014, 01:07 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
You literally don't need anything better than this: http://www.radioshack.com/product/in...uctId=16484196
But you can probably get by just fine with 16 or 18 gauge. 12 gauge looks nicer, though.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
post #14 of 227 Old 07-27-2014, 01:17 PM
89grand's Avatar
Quoted: 288 Post(s)
Liked: 163
I use these, they look pretty cool and they are affordable. I don't really feel I need 12 gauge wire, but that's how they come.
http://sewelldirect.com/Silverback-S...Terminated.asp
BGNewB likes this.
89grand is offline
post #15 of 227 Old 07-27-2014, 02:37 PM
Bill Fitzmaurice's Avatar
Liked: 4637
Electrons don't know how much your speaker cost, nor do they care. Read this:
http://www.skeptic.com/eskeptic/10-01-06/#feature
Cvetan1, sage11x, icelt and 4 others like this.
Bill Fitzmaurice is online now
post #16 of 227 Old 07-27-2014, 03:10 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
Those look nice, and very reasonable. If my runs weren't odd lengths, I'd consider swapping out for a set.
Gecko85 is offline
post #17 of 227 Old 07-27-2014, 03:28 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Cu2O is a perfect insulator so the older the cable the better the transmission esp the more"oxygen free" the copper.
Ag2O and Au2O are great conductors.
Soo based on above, you will need crimp fresh the terminations and attach with high silver content solder to a gold plated spade>banana-plug>pin in descending order of quality of connection.
You will need to get extra spades because you will ruin a few in the learning process by melting off the gold if temp is too high.
Materials: Belden 10AWG cable, electrical tape (to cover solder points), gold plated spades, crimp tool, butane torch or an electronic air rework tool, and a DaVinci robot, just kidding, one like this:
bobpaule is offline
post #18 of 227 Old 07-27-2014, 04:18 PM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
I am confident you method will work as good as simply using bare wire or any one of several spades and banana plugs that require no solder.
One question. Why do it the hard way when it will not improve the sound quality?
post #19 of 227 Old 07-27-2014, 04:57 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
This should be all you need if you want 12ga wire.
http://www.monoprice.com/Product?c_i...seq=1&format=2
They also come in other lengths if you need more wire.
jaeelarr and Nodscene like this.
Afro GT
afrogt is online now
post #20 of 227 Old 07-27-2014, 07:42 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Simply because oxidation will also occur at the very end of the copper wire where it meet your solderless shiny connectors, and SQ will drop in time.
A compromise I guess, one that will work very well is to just melt the high silver solder into the crimped endings then mechanically attach it to the solderless connectors.
Regards
bobpaule is offline
post #21 of 227 Old 07-27-2014, 07:44 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Simply because oxidation will also occur at the very end of the copper wire where it meets the connectors, and SQ will drop in time.
A compromise I guess, one that will work very well, is to just melt the high silver solder into the crimped endings then mechanically cold attach it to the solderless connectors.
Regards
bobpaule is offline
post #22 of 227 Old 07-28-2014, 02:21 AM - Thread Starter
Quoted: 129 Post(s)
I use Monster THX Surround Cable for all speakers. Any good?
post #23 of 227 Old 07-28-2014, 03:56 AM
Cal68's Avatar
Quoted: 196 Post(s)
Liked: 144
I think that the answer you will get from most people on AVS is that while there is nothing inherently wrong with the ability of Monster cables to transport signals, the cables themselves are vastly overpriced. You can get cables that perform just as well, but for a fraction of the price, from either Monoprice or Blue Jeans Cables.I've bought all sorts of cables from both vendors and they have been great for me.
Cal68
Cal68 is online now
post #24 of 227 Old 07-28-2014, 04:23 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
fatbottom is offline
post #25 of 227 Old 07-28-2014, 05:34 AM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
Originally Posted by fatbottom View Post
Why would you recommend a non THX cable
post #26 of 227 Old 07-28-2014, 06:22 AM - Thread Starter
Quoted: 129 Post(s)
I too wonder why.
post #27 of 227 Old 07-28-2014, 06:31 AM
Liked: 4637
I too wonder why.
One can't know if you're serious or not, but in any event there is no such thing as a THX cable, at least not from a technical standpoint. From an advertising standpoint perhaps, but if the advertising even mentions THX then you can very safely assume that the product is snake oil. That title applies to anything and everything made by Monster, and Kimber as well.
post #28 of 227 Old 07-28-2014, 06:32 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
I too wonder why.
That was sarcasm
This is a long debated topic; but it comes down to this: Transporting a signal from the amplifier to the speakers is an objective goal, for which solid copper wiring is sufficient. It is easy to get caught up in all the pseudo-science of expensive cables, but you need to remember that the basic Radioshack cable does just as good a job as the thousand-dollar Audioquest cable.
The Radioshack cable seems to be a very good option, or if you want to get some pre-terminated cables, check out Blue Jeans Cable. I use Monoprice cable and it has been great for me.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #29 of 227 Old 07-28-2014, 06:38 AM
fatbottom's Avatar
Liked: 518
Lol bought a 20A cable for £5
http://www.russandrews.com/product.a...HVHHIKGCHVYUSU
That costs more (in 2M config) than a 7 channel, ATI, 2003, 7 x 200W power amplifier. hahaha.
post #30 of 227 Old 07-28-2014, 06:39 AM - Thread Starter
Quoted: 129 Post(s)
Originally Posted by Transmaniacon View Post
That was sarcasm
I can easily hear the difference between an AudioQuest and a came in the box run off the mill PS3 cable.. or a Monster XPHP and a Monster THX Surround cable.
Reply Speakers
