Best Audio CD Burning Software??? Windows Media Player compresses files ! A No No - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 07-27-2014, 06:55 PM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
It seems to me like the Windows Media Player is actually compressing file size?? can that be? for Audio CDs.
I had 6 WAV songs I added to Audio CD. Total size was 700mb while my CD-r is exactly 750mb. Somehow software says only 50% is full and it goes by total song length.
I still kept it at 6 songs and burned the CD. After burn, looking at the CD write side it clearly shows that it used up 50% of available surface. So what is happening??? is it compressing my WAV files to smaller MB ?
thank you.
P.S. Is there a better software to use for CD burning??
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, WD TV Live Media Player, Samsung BD ES6000, Denon DVD-2910 & Sony BDP-S370 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is offline
post #2 of 17 Old 07-27-2014, 07:22 PM
grasshoppers's Avatar
Quoted: 853 Post(s)
Liked: 544
What does this have to do with speakers??
grasshoppers is online now
post #3 of 17 Old 07-27-2014, 07:32 PM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
Sorry couldn't find the appropriate forum but hoped many here would know.
post #4 of 17 Old 07-27-2014, 07:51 PM
Quoted: 853 Post(s)
Liked: 544
Quick forum search revealed this thread.
What's the best CD ripping software?
post #5 of 17 Old 07-27-2014, 10:39 PM
charmerci's Avatar
Quoted: 315 Post(s)
Liked: 201
thank you.
CD length should be about 80+ minutes of music so if the 6 songs were 40 minutes long, that's just about right.
charmerci is offline
post #6 of 17 Old 07-28-2014, 12:01 AM
t1337Dude's Avatar
Quoted: 172 Post(s)
Liked: 117
IMGBurn is free and perfect. I use that.
t1337Dude is offline
post #7 of 17 Old 07-28-2014, 08:29 AM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
That I understand but I thought that a CD-R 700mb limit was either 700mb of space or 80 min .... one or the other. First one that reaches limit is the control. In this situation I know that file size if beyond 700mb as music files are very big and yet it tells me that I am only half way through the max space on CD>
post #8 of 17 Old 07-28-2014, 10:26 AM
afrogt's Avatar
Quoted: 1362 Post(s)
Liked: 943
In Windows Media Player you have several options in which to save a music file. When ripping a CD if you use WAV Lossless the file will not be compressed. There is a WMA Lossless and a WAV Lossless. The other options are compressed.
As long as the WAV file was lossless it should burn the same way.
Name:	Windows Media Lossless.PNG
Afro GT
afrogt is online now
post #9 of 17 Old 07-28-2014, 10:52 AM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
I'd actually be burning on to a CD instead of ripping one.
post #10 of 17 Old 07-28-2014, 10:56 AM
afrogt's Avatar
Liked: 943
Yes, but how did you get the WAV files in the first place? Did you rip them from a CD?
Afro GT
post #11 of 17 Old 07-28-2014, 10:58 AM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
so when I burn a WAV file that is 200mb and recording is in 5130kbps 192 quality .... what I hear out of my SACD/CD player is no where close to that file capability ??? It gets "downsampled" to standard CD music file that maybe 1411kbps or something like that?
post #12 of 17 Old 07-28-2014, 10:58 AM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
nope ... downloaded from site that has these high end music recording probably ripped from SACDs or some other top quality source.
post #13 of 17 Old 07-28-2014, 11:07 AM
Transmaniacon's Avatar
Quoted: 1582 Post(s)
Liked: 1381
Just use IMGBurn as was mentioned above, it will verify the burned copy against the source.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #14 of 17 Old 07-28-2014, 11:45 AM
PCMusicGuy's Avatar
Yes. If you burn in audio CD format it will down res/sample to 16 bit, 44.1 kHz.
PCMusicGuy is offline
post #15 of 17 Old 07-28-2014, 12:25 PM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
and if I burn as a file CD??? or as they say Data CD
post #16 of 17 Old 09-06-2014, 02:44 PM
PCMusicGuy's Avatar
If you burn as a file, the full resolution is kept; the issue is finding something other than a computer that can play it.
post #17 of 17 Old 09-06-2014, 03:06 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
yup if you burn it as audio CD it will have to convert it keep it to red book standard.
http://en.wikipedia.org/wiki/Compact...io#Sample_rate
If you have PCM tracks higher than 44.1khz 16 bit you will have to use data type, CD players won't read them so you'd need a computer, or a media streamer.
fatbottom is offline
Reply Speakers
