Speaker Position - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By mtn-tech
  • 1 Post By Transmaniacon
post #1 of 20 Old 07-28-2014, 03:20 PM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Speaker Position
Hi!
My basement work is finally done and got the chance to set up home theater on the weekend. However, I am a bit unsure about the placement. I originally wanted to wall mount the front speakers but they seem a bit big to mount, it wouldn't look good. And I am unsure of the placement of the sub?
Here is what the room looks like now.
Would they be ok on the floor? Or should I get at least stands for them? Also I have no idea where to put the subwoofer. All the websites show it beside the couch, half way in the room. Unfortunately I did not have the fore sight to think of that, so I would have to run the wire from the front along the sides to do that. It is not ideal :P
Where else is a good spot to put it?
The speakers are Polk Monitor 45B (Front), 35B (Rear/Surround), 15C (Center) and BIC F-12 Sub. And thanks to JWagstaff for helping me pick em out
THanks!
Crzyrio is offline
post #2 of 20 Old 07-28-2014, 03:37 PM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
The front speakers should be on stands so the tweeters are at seated listener ear height - prefer steel stands for their weight but wood is OK as well. Angle them in toward the listener just slightly.
Google sansus speaker stands
Is that a center speaker on a shelf below the TV? If so, make sure it is moved forward as much as possible so the sound doesn't reflect off of the wall / shelf / TV.
For sub placement, it depends on your room - every room is different. Search AVS for "subwoofer placement" or "subwoofer crawl" to learn the best ways to determine optimal sub placement.
dsrussell likes this.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #3 of 20 Old 07-29-2014, 07:17 AM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Thank you very much for the reply. The stands you suggested are much cheaper than the others I've seen
http://m.bestbuy.ca/?lang=en#/catalog/productdetails.aspx?ajax=true&sku=10061848&lang=en-CA
The Center speaker sits in line with the wall/tv. The TV is recessed into the wall a swell as the shelf. So it just slightly sticks out of the wall.
Will give the Crawl a try
There are a couple questions I have about the speaker settings as well but don't remember the terms right now. Will update when home. There's the option to change the Hz of the speakers 80Hz, 60Hz etc. what does this do? I used the automatic setup with the Audessy but still curious
Crzyrio is offline
post #4 of 20 Old 07-29-2014, 07:28 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
http://m.bestbuy.ca/?lang=en#/catalo...848&lang=en-CA
Yes those stands are a good option, a 24" stand should get the tweeters in the 45B about even with the center tweeter. I would space out the front speakers a little more, and as was mentioned toe them in towards the main listening position some. Putting the sub in a corner on an angle similar to how you have it helps add some gain, and in what looks to be a big open space, this would probably be a good idea. But experiment and see where it sounds best to you. Remember subs are omni-directional so don't feel like you have to point the sub at the seats.
The "Hz" in the receiver settings is the crossover frequency. Audyssey will determine the lowest value you can use, but I would go in and change the fronts to 80Hz if they are set lower. The center maybe 80 or 100Hz. Your surrounds are likely at 100Hz. Make sure it set all your speakers to small, so the sub handles the bass. On the back of the sub, set the crossover to the highest point, phase to zero, and volume to 30-40%. Re-run Audyssey and make sure the sub volume level in the receiver is at or close to 0dB. If it is negative, turn your sub volume down some, and if positive, raise the sub volume. You want to find the proper volume on the sub, then if you want to raise/lower the bass, do so in the receiver.
mtn-tech likes this.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #5 of 20 Old 07-29-2014, 10:58 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Another option for speaker placement are wooden wall shelfs. Sort of like this one, but a little shorter in length.
Get an unpainted one and then paint it to match the trim. The advantage of speakers stands, though, is that it hides the wires. With the wall shelving, I would find some white speaker wire like this: http://www.amazon.com/Monster-Navajo...dp/B00006I5GV/
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #6 of 20 Old 07-29-2014, 07:18 PM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Thanks! I found the exact stands on local classifieds (kijiji) for $20, so went ahead with it Here is what I am at now with all the advice taken in.
Also, how do I go about securing the speakers to the stand? There no screw hole on the bottom of the speaker or anything. Double sided tape should be enough? :S
I haven't had the chance to change any settings but will give all this a try this week. That 2nd paragraph in particular gave me a lot of changes to make If I remember correctly the volume on the receiver for the sub showed 12Db so deff need to adjust that. Aswell the phase I just left it at 120Hz I believe.
What exactly does setting the base on the sub to the max frequency do??
I am hoping Ill get a chance to play with the sub placement this thu, and clean up all the wires with some fishing on friday.
I wanted to keep that wall as clean as possible. If I could make recessed shelves in the walls for the speakers than I would do that.
Crzyrio is offline
post #7 of 20 Old 07-30-2014, 04:47 AM
Liked: 1394
The speakers should be sturdy enough on there, some people use Blu-Tack which you can find on Amazon to stick the speakers to the stand. It won't damage the finish or leave a residue, and helps keep them a little more stable.
Your sub has a low pass filter on it (the crossover dial) and this is used if you don't have bass management via a receiver for example. By turning the crossover to the highest point, you disengage the subs low pass filter and let your receiver handle the crossover.
post #8 of 20 Old 07-30-2014, 05:16 AM
pkrfan's Avatar
You have a nice room. Make sure you add room treatments. With that wood floor and bare walls your going to get a lot of reflection. I would add a large rug and soft furniture. There are also wall treatments that can be added as well.
pkrfan is offline
post #9 of 20 Old 07-30-2014, 07:16 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 338
To improve your sound you might want to looking into a large thick rug in from the the TV. It will help absord some of the highs and make your room less echo-y
What receiver do you have?
Did you run its room calibration set-up? What were the settings the receiver gave your speakers? (this helps us see if your speakers were set up right cause Audyssey isn't right 100% of the time)
You sure it set the subwoofer at 12db or was it -12db?
crazyrob425 is offline
post #10 of 20 Old 07-30-2014, 05:15 PM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Thanks! Will look into Blu-Tack, Im more worried about someone tipping it over. 1 more question with regards to cross over. When using Audessy it said one of my speakers is out of phase and asked me to flip the red & black wires, after doing so it was fine. Is this normal?
Thanks! What do you mean by 'soft' furniture? We plan on doing the rug, and likely a leather couch for now.
It is the Denon AVR-e300 -> http://www.accessories4less.com/make...airplay/1.html
Thanks! I will post up all the settings the calibration gave me sometime tomo and will double check the subwoofer volume :P
Crzyrio is offline
post #11 of 20 Old 07-31-2014, 05:38 AM
Liked: 1394
Yeah that is not a big deal about the phase, Audyssey checks for that and makes sure everything is wired correctly.
Soft furniture just means cushioned surfaces, not glass/wood/metal. Putting a big area rug down in front will help with floor reflections, and if there are windows, drapes help reduce reflections off windows. One good investment that you can make, either via purchase or DIY, is acoustic panels. You can get nice looking fabric or do printed designs, stretched over a frame and hung on the wall at the primary reflection points. This makes a huge difference in sound quality and can add a nice decorative element to the room.
post #12 of 20 Old 07-31-2014, 11:38 AM
carp's Avatar
Quoted: 2827 Post(s)
Liked: 2133
I use this to keep my subs from shifting since they are stacked from floor to ceiling in the front corners of the room. It would be pretty scary if the top sub fell off!
Since I put it in between the subs they have not budged at all. Good stuff.
http://www.homedepot.com/p/QuakeHOLD...8111/100143045
carp is offline
post #13 of 20 Old 08-01-2014, 06:19 AM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Here are the settings that Audessy sets.
A few things I am noticing that I do not like. I can barely hear that bass punch when it comes to music but the bass sounds great for movies (could be my music files?). All the music is very trebly. Maybe this will fix it self once I follow your advice with regards to soft furniture and a rug?
For movies it sounds awesome but everything is loud. When I sit in the spot where I did the setup from, it is hard to distinguish the surround sound. I have to move back closer to the rear speakers to really get the surround sound effect. Should I just down the front speakers a bit?
Also if -12 sound right for the sub? :S
Crzyrio is offline
post #14 of 20 Old 08-01-2014, 06:23 AM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Looked into the acoustic panels and definitely seem interesting if we can find some with patterns or something. Only thing is where to put it, the left side of the TV is open space and there is a long wall on the right. So it would go on that wall then? Ill try and post pics of the entire basement.
Thank you! This looks like a viable option. Are you able to see it under the sub? Or can you spread it thin enough that it is not noticeable?
Crzyrio is offline
post #15 of 20 Old 08-01-2014, 06:30 AM
Liked: 1394
One issue however is the sub level is too high. Your receiver has the level at -12dB, which means you need to turn down the sub and re-run Audyssey. You want the measured level in the receiver to be at 0dB, or within +/- 0.5dB. This should help make things sound better. If after this is done you want more or less bass, add to the level in the receiver. The goal here is to find the right gain to keep the sub at so it works properly with your setup.
The accentuated high frequencies are likely due to all the reflections off hard surfaces. Get your a big area rug and hang drapes on any windows in the room. You may also want to look into some acoustic treatment, you can make your own panels relatively easily, using a wooden frame with fabric stretched across.
You may want to adjust the position of your surrounds, it looks like they are shooting out over your head towards the front. You want the tweeters pointed at your ears, so it looks like they need to be turned inward and down.
Also make sure to do the calibration from where your head would be, not in the middle of the room somewhere. Audyssey will tell you to move the mic several times, so make sure you are placing it in the correct locations as shown on screen. If you are sitting on a sofa, think of the three areas as three people's heads sitting there, to help get your position correct. And if you add any furniture or rugs/wall coverings, make sure to re-run Audyssey.
post #16 of 20 Old 08-01-2014, 06:31 AM
ALtlOff's Avatar
Quoted: 1183 Post(s)
Liked: 590
Basically you're at the point where you have to start adjusting things to "your" liking, everyone hears different and likes there systems set differently.
As far as the -12, that could be caused by a few things, but good chance that it's in part to the sound reflection that was mentioned earlier.
Best thing now is to work on your room treatments, rugs and panels, this will change a lot of things and no sense in getting it just the way you want and having to go through it all over again once you add those things.
You're almost there.
(Ooops, sort of double posted with trans., you get the idea.
ALtlOff is offline
post #17 of 20 Old 08-01-2014, 09:58 AM
cel4145's Avatar
Liked: 3002
+1 to all this
Also, Audyssey is picky about how you have the mic positioned (direction). Be sure to follow instructions carefully and read some tutorials if you have not already.
cel4145 is offline
post #18 of 20 Old 08-01-2014, 10:22 AM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
The stands look great - good find. Your tweeters look to be close in height across the front three speakers which is ideal.
I haven't had the chance to change any settings but will give all this a try this week. That 2nd paragraph in particular gave me a lot of changes to make If I remember correctly the volume on the receiver for the sub showed 12Db so deff need to adjust that. As well the phase I just left it at 120Hz I believe.
You should set the phase control on the back of your sub(s) to zero - your AVR will do phase matching at its crossover point to blend the sub as part of the room EQ - at least Audyssey does.
You probably could between studs, only problem with that is if your speakers are ported - especially with the port on the back - they will actually sound better moved out from the wall the way that you have them on the stands.
mtn-tech is offline
post #19 of 20 Old 08-08-2014, 05:45 AM - Thread Starter
Crzyrio's Avatar
Quoted: 20 Post(s)
Thanks for all the info thus far guys, its made a HUGE difference. We've been busy so havent had much time to finish the furnishing.
This solved it thanks . I tilted them down some more and the difference is quiet significant. Playing video games is never going to be the same lol.
Thanks! We are going furniture shopping this weekend and found some acoustic panels on kijiji for decent prices. Where would I put them though? On the side wall or back wall? There will be a couch and such between the speakers and the back wall so In my mind it doesnt make sense. There is only a wall on the right side so would it be useful to put it on the side half way down?
Crzyrio is offline
post #20 of 20 Old 08-08-2014, 06:23 AM
Liked: 1394
You want them at the main reflection points. Here is an excellent article on room acoustics from GIK, I would recommend reading through it and it will help you understand how sound interacts in there, and where you want to be placing your panels.
http://www.gikacoustics.com/acoustic-primer/
Reply Speakers
