Amplifier Advice - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Transmaniacon
  • 1 Post By cel4145
  • 1 Post By zieglj01
post #1 of 10 Old 07-29-2014, 12:55 AM - Thread Starter
arsenal009's Avatar
Amplifier Advice
Hey guys,
I need to set up speakers for my desktop.
I already have 2 Polk Audio RM1300 satellite speakers from my old 5.1 system that I want to use as my speakers.
The manual can be found here (specs on p.15): http://www.manualslib.com/manual/311...page=15#manual
Here are a couple of the specs stated in the manual:
Nominal Impedance - compatible with 8 ohm outputs
Recommended Amplification: 20-125Wrms
I'm looking for an amplifier to go with my 2 speakers. I want the amp to include a headphone jack, volume control, base control, & a power on/off switch. I also require all the cables necessary.
Can u guys give me some suggestions?
arsenal009 is offline
post #2 of 10 Old 07-29-2014, 05:30 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
What is your budget? This is the cheapest option I know of: http://www.parts-express.com/topping...utput--310-310
The only cables you will need are speaker wire, and a 3.5mm to RCA cable
However you don't get bass controls, but I wouldn't recommend artificially boosting the bass in a satellite speaker anyway, it probably can't play much below 120Hz, so you will just be creating distortion and limiting headroom. If you want bass, add a sub to the mix.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 10 Old 07-29-2014, 11:00 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Agreed. Topping is a good choice for a small amp. If you want more power and more controls, the Denon 1513 would work quite well
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #4 of 10 Old 07-29-2014, 11:23 AM
zieglj01's Avatar
Quoted: 1678 Post(s)
Liked: 1576
What do you plan to do for bass - the small sats will be weak in the bass
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #5 of 10 Old 07-29-2014, 11:48 AM - Thread Starter
arsenal009's Avatar
I want bass control so I can put the base down to zero, lol.
I have bass on my 5.1 system for watching tv. But it gives me a headache when I'm on the computer.
post #6 of 10 Old 07-29-2014, 11:50 AM - Thread Starter
arsenal009's Avatar
I want bass control so I can turn off the bass
post #7 of 10 Old 07-29-2014, 11:51 AM
Liked: 1394
I don't think you will need to worry about that with a pair of satellite speakers
arsenal009 likes this.
post #8 of 10 Old 07-29-2014, 11:53 AM
cel4145's Avatar
Liked: 3002
Denon 1513 would be your best bet, then. Unless you want to use Equalizer APO to EQ down the bass on your computer. Your computer soundcard software might have a graphical EQ that would let you do something similar (and easier). For example, something like this on some of the Asus Xonar sound cards:
cel4145 is offline
post #9 of 10 Old 07-29-2014, 12:32 PM
zieglj01's Avatar
Liked: 1576
It will be a small miracle, if those sats have any real bass below 140 hz
So, you have a chance of getting a new headache.
Who AM I
post #10 of 10 Old 07-29-2014, 02:27 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
I use one of these for my personal computer audio. It provides 100 watts per channel, has a great built in headphone amp and even an FM tuner. $82.
FMW is offline
Reply Speakers
