Should I upgrade to JTR Triple 12HTs from Polk RTI A9s? - AVS Forum | Home Theater Discussions And Reviews
Old 07-29-2014, 09:38 AM - Thread Starter
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 217
Send a message via Skype™ to ahmedreda
I have polk RTI A9 / A6 / A5s. I have been fairly satisfied with their performance. I have a friend who is offering me the 3 JTR triple 12HTs for a good discount.
I normally listen at fairly moderate volumes (-17.5 MV) with the subs being about 5 dbs higher.
From what I read the JTRs have more of a dynamic sound and I read also from someone that they started listening louder after they switched to the JTR.
This is going to be a significant uprade money and effort wise so I want to make sure it will be worth it before I commit. Would it be a night and day difference in sound quality at the levels I listen to? I also noticed that they are fairly sensitive speakers. Does that mean I can sell my emotiva amplifiers and rely on the receivers to drive them without losing any of my current headroom? Any feedback would be appreciated.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
Old 07-29-2014, 09:56 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Hi, the first thing I'd suggest is to talk to your friend about letting you hook up the Triple 12s in your room so you can more easily make the decision. On paper, there's a huge increase in efficiency going with the JTRs, over 11db so lots of get up and go with even receiver power. You'll probably inevitably start listening louder not necessarily because you can but because it won't sound like you're at the levels you are. -17.5 MV will be a mere blip on the radar. I had Triple 12s and liked them and in general always prefer dynamic speakers for the headroom. I want my own preference to be the limiting factor not my speakers or subs. Good luck!
gpmbc is online now
Old 07-29-2014, 10:09 AM - Thread Starter
ahmedreda's Avatar
Quoted: 302 Post(s)
Liked: 217
So are you saying that they won't sound good at the lower volumes I am used to?
My home theater
Display: JVC RS400
Old 07-29-2014, 10:34 AM
ousooner2's Avatar
Quoted: 260 Post(s)
Liked: 155
Lower distortion doesn't sound as 'loud'
..Is what he's getting at I believe
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
Old 07-29-2014, 10:41 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
^^^ That's what I meant.
gpmbc is online now
Old 07-29-2014, 12:09 PM
RMK!'s Avatar
Quoted: 1604 Post(s)
Liked: 1479
Significant upgrade = yes
Night and Day Difference = depends
High Efficiency = separate amps not needed.
As gpmbc said, best to hear them in your room to get he full effect. I was able to do that prior to my first JTR Triple 12 buy and it sold me on them.
Good luck and good listening.
Opinions are not facts.
RMK! is online now
