Infinity Primus p153 or p163 - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2014, 01:39 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 1
I have found the infinity P163s for sale only $10 more than the p153s. Is it a better buy for the bigger speaker? They are going to be used for my rear channels. I did see some talk about the P153s being a better rear channel?
I have the pc351 center and p363 towers. Using them with a PSA XV15 sub.
Thanks for info!
Dwalinn is offline
Old 07-31-2014, 08:08 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
The P153 comes with a wall mount bracket if you need it. The larger P163 does not.
If you're not wall mounting and have the room for P163's I'd probably get them since its only a $10 difference.
For $10 why the hell not.
Afro GT
afrogt is offline
