Dented Dust Cap HELP!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-02-2014, 06:40 AM - Thread Starter
MEGATURON's Avatar
Quoted: 154 Post(s)
uhh my baby boy just dented my dust cap, will this affect the sound quality of my speaker if so how can I fix. I tried using packaging tape but still it wont work the dust cap is kinda hard. please help!
EDIT: ok after using heavy duty packaging tape finally it popped ^^ but would this still affect the sound?
ID:	192961   Click image for larger version
ID:	192969   Click image for larger version
MEGATURON is offline
post #2 of 8 Old 08-02-2014, 07:49 AM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 125
I doubt you would have heard a difference even while it was dented.
Relax and enjoy your speakers.
koturban is offline
post #3 of 8 Old 08-02-2014, 09:08 AM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
And put the grilles back on, will prevent your son from damaging the speakers.
Afro GT
afrogt is offline
post #4 of 8 Old 08-02-2014, 09:11 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Hi can you tell me which heavy duty tape did you used? My dust cap was also pushed by my son. Thanks
caloyzki is offline
post #5 of 8 Old 08-02-2014, 11:51 AM
crn3371's Avatar
Quoted: 257 Post(s)
Liked: 206
+1
Naked speakers are fine when there are no kids in the house. Put those grills back on!
crn3371 is offline
post #6 of 8 Old 08-02-2014, 01:14 PM
tvrgeek's Avatar
Quoted: 18 Post(s)
Liked: 33
Yes, put the grills on.
The may sound better as dust caps have very nasty break-up modes. An off center dent can help to break them up giving a smoother sound.
Now, I have used 3M structural foam tape to pull dents from aluminum and poly dust caps.
tvrgeek is offline
post #7 of 8 Old 08-02-2014, 06:50 PM
kpotier16's Avatar
Quoted: 14 Post(s)
I think you should be fine, another trick if the tape doesnt work is to use a vaccum cleaner. You should use an end on it that is smaller than the dust cap and round though.
kpotier16 is offline
post #8 of 8 Old 08-02-2014, 11:30 PM - Thread Starter
MEGATURON's Avatar
Quoted: 154 Post(s)
Ok thanks everyone i thought its something serious btw i used scotch from 3m its a heavy duty packagingtape just go to ur nearest school store they should have it.
Reply Speakers
