Initial hook up for B&W CM5's and Center Channel - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By grasshoppers
  • 1 Post By postrokfan
  • 1 Post By whikx250
Old 08-03-2014, 09:26 AM - Thread Starter
whikx250's Avatar
Just ordered B&W CM5 and matching center. My Sub is SVS PB12. 2 Satellites are KEF. Wondering what this forum thinks is the best way to hook this all up. All powered by a Marantz SR7008. Can I use the bare speaker wire on current system and just switch the components or are banana plugs better for these speakers? Also, Do you think there is a need for an additional amplifier for more power?
whikx250 is offline
Old 08-03-2014, 11:52 AM
grasshoppers's Avatar
Quoted: 766 Post(s)
Liked: 458
Banana plugs are a nice convenience, not
A necessity. Bare wire works just fine.
Your Marantz should have plenty of power for
Your speakers. Also, with your nice sub you
Will probably be using bass mgmt which will
Lessen the load on the Marantz even more!
Nice speakers....enjoy!
whikx250 likes this.
grasshoppers is online now
Old 08-03-2014, 12:42 PM
postrokfan's Avatar
Quoted: 477 Post(s)
Liked: 2736
Agreed. Banana plugs are a nice convenience but not a necessity. The CM5s dip down to 4.4 ohms (http://www.soundandvision.com/conten...-labs-measures) but the Marantz SR7008 should handle the CM5s with no problem especially with Audyssey engaged.
HT/Living room: FR/FL Sierra 1 NrT, Sierra-1 NrT Center, B&W ASW610, Yamaha RX-A2030, Oppo BDP-93, ATV.
2-channel: B&W 804D, B&W ASW608, Parasound P5, Parasound A23, Marantz CD5004, Rega RP1, Bluesound Node2.
postrokfan is offline
Old 08-03-2014, 01:37 PM - Thread Starter
whikx250's Avatar
With Audyssey engaged will there be much or any speaker setting adjustments on the Marantz?
whikx250 is offline
Old 08-03-2014, 02:35 PM
Quoted: 766 Post(s)
Liked: 458
Sometimes Audyssey sets crossover points too low.
With those speakers I would set them at 80hz...
But no lower than 60hz.
Old 08-05-2014, 07:00 AM - Thread Starter
whikx250's Avatar
Bi amping the fronts won't effect the Audyssey function would it? Also, Can the B&W CCM center be Bi amped?
whikx250 is offline
Old 08-05-2014, 07:35 AM
Quoted: 766 Post(s)
Liked: 458
No and No.
Old 08-08-2014, 05:06 PM - Thread Starter
whikx250's Avatar
Finally have the new receiver, new sub, and new fronts setup and playing some music. Biamped this time around. What a jump in performance from the old setup. Center channel comes in tmrw. Imagine my novice shock when last night no dialogue played during "IronMan". Brief armchair grabbing wide eyed horror. Worth the cash.
whikx250 is offline
Old 08-08-2014, 06:48 PM
drewTT's Avatar
Quoted: 569 Post(s)
Liked: 594
Nice. CM5s are fantastic speakers!
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
Old 08-08-2014, 09:37 PM - Thread Starter
whikx250's Avatar
They are wonderful paired with the SVS PB12 Plus. I was poised for the Paradigm S2's but saved a bundle and not a huge sound difference IMHO. Ive been listening to various types of music for hours and the B&W's deliver. I think the fullness the sub brings has alot to do with it. Leaves nothing lacking on any level. My other system sucked.
postrokfan likes this.
whikx250 is offline
