Speakers on floor stand keep falling over - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-03-2014, 10:55 AM - Thread Starter
pizzaboy's Avatar
Between the kids and the dogs, these get knocked over at least once a week.
Ideal stand would have a longish flat foot that I could wedge under couch so that the stand was anchored...
Thoughts?
pizzaboy is offline
post #2 of 11 Old 08-03-2014, 12:00 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Attach the current base to some plywood.
You can drill through the base and attach to the plywood. Get the plywood long enough to slide under the couch.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #3 of 11 Old 08-03-2014, 12:41 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
The aforementioned piece of wood would work. If you have access to some small barbell weights, you could put those on the base pole. Put enough weights on there to counteract the dogs and kids... or dispose of the kids and dogs. Your decision.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #4 of 11 Old 08-03-2014, 12:43 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Buy some better stands. A bomb wouldn't knock these over.
fatbottom is offline
post #5 of 11 Old 08-03-2014, 12:45 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Put some plate barbell weights on the bottom.
crazyrob425 is offline
post #6 of 11 Old 08-03-2014, 08:58 PM
Shadowed's Avatar
Quoted: 639 Post(s)
Liked: 542
Sand bag weights could help and you can use almost any material you like.
You could probably even find something to match the couch.
http://rasterweb.net/raster/2011/05/17/simple-sandbags/
Shadowed is offline
post #7 of 11 Old 08-03-2014, 09:44 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Slide a 25lb weight on there and it won't go anywhere.
crn3371 is offline
post #8 of 11 Old 08-03-2014, 10:09 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
Wow, those are some serious stands.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #9 of 11 Old 08-04-2014, 06:52 AM
orsen's Avatar
i had the same stands with the same problem
couldnt sell em so they are now at the scrap yard
orsen is offline
post #10 of 11 Old 08-05-2014, 09:03 AM - Thread Starter
pizzaboy's Avatar
Hmmm....
pizzaboy is offline
post #11 of 11 Old 08-05-2014, 09:40 AM
Playdrv4me's Avatar
Quoted: 56 Post(s)
Liked: 94
Those stands are *AWFUL*. I used to have something identical and I believe the same chinese company has been making those things for the better part of 20 years. The design inherently lends itself to tipping over, and on carpet they barely weigh enough to keep the poles EVEN AND STRAIGHT.
Modify them significantly (plywood idea sounds interesting, but what you need most is weight) or replace them with something even a level or two above that.
Playdrv4me is offline
Reply Speakers
