What Surround(rear) Speakers to Buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-03-2014, 11:16 AM - Thread Starter
Liked: 0
Hi experts,
I'm in need of two surround speakers for my 5.1 system. I've been reading about bipole, dipole, Direct-Radiating Monopole, etc. but still have no clue what to get.
Here's what I have:
Receiver: Sony STR DN 1040
Sub: SVS PB1000
Front: GoldenEar Technology Triton Seven Loudspeakers
Center: SuperCenter X
My room is a mid-size room with very little space behind seating position (2 ft) and my budget is around $600.
I originally was considering either one of the Klipsch's reference series or Paradigm Surround 1, but not sure if they are the best choice. At some point, I even considered buying the Klipsch tower speakers and use them as surround/rear speakers.
I would appreciate any advice/suggestion. If you don't know the exact model, it would be great to educate me what I should be looking for, I'll do the looking.
excalibour is offline
post #2 of 15 Old 08-03-2014, 11:22 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
Since you're that close to rear speakers, I'd definietly look into diffused speakers.
I own dipole and bipoles. have used dipole on side, bipole on rears but I bought another set of identical bipoles so I have bipoles on sides & rears. About 3' away from sides and rears. Much prefer diffused when you're that close.
Use BP-2X now.
I'd try and match with the fronts, but if matching rears aren't available, or just too expensive (ie compare SVS Ultra bookshelf to the SVS Ultra rears) then just get good quality surround speakers.
fatbottom is offline
post #3 of 15 Old 08-03-2014, 11:47 AM - Thread Starter
Liked: 0
Use BP-2X now.
Because of the space limitation, I planned to use either bipole or dipole speakers on side (3-4ft distance from sitting position). You said you replaced dipole with bipole, why? Do dipoles create to much spaciousness?
post #4 of 15 Old 08-03-2014, 11:51 AM
fatbottom's Avatar
Liked: 520
I still have the dipoles, but I think with modern soundtracks the need for dipoles isn't required so much. If I wanted I could re-wire the dipoles to convert them to bipoles, just a 10 minute job.
Bipoles are more direct sounding surround speaker.
Dipoles sound like when you have one ear bunged up, you can hear it from the other ear, but not so much and it's hard to tell exactly where it is. That is the dipole effect if listening to a single dipole if the face of the speaker is facing towards you (drivers firing out to 3 and 9 o clock)
post #5 of 15 Old 08-03-2014, 11:53 AM
theskins44's Avatar
Quoted: 26 Post(s)
check out AXIOM AUDIO's Qs8's or the qs4's and they are very forgiving in placement options
b stocks when available are a steal
I have 4 qs8's and love them
theskins44 is offline
post #6 of 15 Old 08-03-2014, 11:57 AM
theskins44's Avatar
Quoted: 26 Post(s)
also refurb store has v3 qs8's for a lot less
axiomaudio.com
post #7 of 15 Old 08-03-2014, 12:20 PM
zieglj01's Avatar
Quoted: 1672 Post(s)
Liked: 1569
These are bipole/dipole switchable - HTD Level Three - a good price
http://www.htd.com/Products/level-th...REE-Surround_2
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #8 of 15 Old 08-03-2014, 12:45 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
hi, if i am using a dipole/bipole for my 5.1 surrounds which one shoud i use dipole or bipole? if 7.1 which one should be use dipole/bipole? thanks.
caloyzki is offline
post #9 of 15 Old 08-03-2014, 12:53 PM
fatbottom's Avatar
Liked: 520
If you have one set of bipoles, and one set of dipoles
Dipoles on the sides
Bipoles on the rears
Or you can use
Bipoles on the sides
post #10 of 15 Old 08-03-2014, 12:57 PM
zieglj01's Avatar
Liked: 1569
Set them up - test it out
Some reading info
http://forum.blu-ray.com/showthread.php?t=66471
http://forum.blu-ray.com/showthread.php?t=170720
Who AM I
post #11 of 15 Old 08-03-2014, 12:57 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Or you can use
thanks. i only have one pair of dipole/and bipole. and direct firing 2 speakers for rears. so side dipole for 7.1? if i want just 5.1 and use my dipole/bipole should use bipole or dipole? thanks
caloyzki is offline
post #12 of 15 Old 08-03-2014, 01:01 PM
zieglj01's Avatar
Liked: 1569
Check the links in post #10
Who AM I
post #13 of 15 Old 08-03-2014, 01:33 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Thanks guys.
caloyzki is offline
post #14 of 15 Old 08-03-2014, 02:00 PM - Thread Starter
Liked: 0
What do you guys think of Polk Audio FXi A4 or A6? I can get an A6 for $500.
Does it worth it or it's overkill?
Edit:
Also, I'm quite intrigued by the idea behind Axiom QS8/QS4. Is it just a gimmick or it actually works?
Klipsch RS-42 II Surround Speaker also seems interesting.
post #15 of 15 Old 08-03-2014, 02:59 PM
bears t2's Avatar
I have a set of the FXi A4 setting on the sides in my 7.1 system. I don't think they are overkill. They have a good solid sound and like some power as all polks do. I run them in di-pole. I think I tried both ways but it seemed to sound about the same to me. Remember just me or I might start a firestorm over bi or di LOL
LG 55LW5600 / Roku3 / Logitech 520
Onkyo TX-NR818
Sony BDP-S570 Blu-Ray, Toshiba HD-D3KU HD-DVD
Bowers & Wilkins 683B (mains), HTM61 (center)
Paradigm Titan v3 (Surrounds), Polk F/XiA4 (Rear Surrounds)
HSU VTF-3 MK5 HP
bears t2 is offline
Reply Speakers
bipole , dipole , rear speakers , surround
