Upgrade to Klipsch R-26f or R-28f - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 108 Old 08-03-2014, 10:21 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Hi guys,
I have a theater room that is sometimes used for music listening as well. Currently my front stage is the Pioneer C21 center and FS51 floorstanders. They are the first version of the Andrew Jones series speakers. Dual RW12 subs, and the 4 surround speakers are Mirage speakers hanging from the ceiling. I am looking for a little more efficiency when listening so music, my receiver gets really hot very quick at loud levels. Since I have the Klipsch subs, I thought it would look nice, since Klipsch speakers are more efficient, if I matched with orange woofers on the speakers as well. I would get the floor standers and matching center as well. What do you think? Good or bad idea? If good, the 26s or 28s? If bad, other suggestions? Thanks.
novisnick likes this.
mgrotel is offline
post #2 of 108 Old 08-04-2014, 01:10 AM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
I would look at the ii reference line. The new speakers are just the synergy with colored drivers.
Reference_head is offline
post #3 of 108 Old 08-04-2014, 07:28 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Is the II series that much better?
mgrotel is offline
post #4 of 108 Old 08-04-2014, 02:49 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1292
Better tweeter and probably better crossover.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 108 Old 08-04-2014, 11:23 PM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
What is the model number of the reference line you guys recommend?
mgrotel is offline
post #6 of 108 Old 08-04-2014, 11:33 PM
novisnick's Avatar
Liked: 29
The RF-28 are a really nice Klipsch product. It's an Icon series and can really stand up to good clean power. I've lived with mine for two years and love them. If you can wait till Thanksgiving you'll be rewarded whit a great price at BB, 1/2 off. Now that's a deal!!! The upgrade this year do sound better. I do know this speaker inside and out.
I also own the reference 61 II and 62 II NICE SPEAKERS, BUT FOR THE PRICE COME BLACK FRIDAY YOU JUST CANT BEAT THEM.
Sorry for the caps, just noticed them.
novisnick is offline
post #7 of 108 Old 08-04-2014, 11:36 PM
novisnick's Avatar
Liked: 29
I use the same black thermal sound blocking curtains behind my TV as well, makes it look so much better. Nice clean look you have there.
post #8 of 108 Old 08-05-2014, 12:11 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
I could be wrong, but isnt the RF-28 the ones with the gray colored woofers? I was hoping to get some that were orange to match the subs I have. But if the gray ones are better then I can deal with the mismatched colors lol.
mgrotel is offline
post #9 of 108 Old 08-05-2014, 07:47 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Sorry, I just re-read your post and you said the new version, I am guessing you are referring to the orange R-28F, sounds better. Are you talking marginally better or are there significant improvements. The older version, RF-28 and RF-26, are both on clearance at my local best buy since the R-26F and R-28F are now on their shelves. Thanks.
mgrotel is offline
post #10 of 108 Old 08-05-2014, 07:51 AM
ClawAndTalon's Avatar
Quoted: 349 Post(s)
Liked: 232
If you can scoop up the old Icons for a good deal, then I'd do that over the new line. The 6" driver is more than enough for most applications. As a matter of fact, I hear little difference except at maybe high volumes with a lot of power (125 watts+) and then the difference is marginal but YMMV.
ClawAndTalon is offline
post #11 of 108 Old 08-05-2014, 08:01 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
Hi guys,
The Klipsch R28 etc. are very poor for the money in my experience.
They are efficient, but that is the only good thing I have heard about them.
If you want some excellent more efficient speakers that will really sound a LOT better, look at a pair of PSB Image T6 speakers with a matching Image C4 center speaker. Around $1600.
I drove them with a 40-watt integrated amplifier when I had them and never ran out of power.
Or if that is more than you want to spend, another great set would be the Wharfedale 10.4 speakers with the 10CC center speaker (around $1100).
They are both more sensitive than your Pioneer speakers, which have unusually low sensitivity. That is their one major problem, as you have discovered (they claim 87 db/watt, but in reality it is more like 85 db/watt, which is poor).
What receiver are you using?
By the way, you really have your TV and center speaker awfully low.
I suggest that you look at the Tech-Craft HBL60 stand, which will give you much more equipment room and get that center speaker up quite a bit.
Amazon sells it for $199, and detailed specs are available at the Tech-Craft website.
commsysman is offline
post #12 of 108 Old 08-05-2014, 08:17 AM
novisnick's Avatar
Liked: 29
Get the older 28s for $500.00 a pair. Haggle with them, they'll give it to you.
Good luck on your journey.
post #13 of 108 Old 08-05-2014, 08:19 AM
oshia86's Avatar
Quoted: 12 Post(s)
Liked: 99
How is it that you've heard so much about the R28? Are we speaking about the new rebranded Icon towers? Didn't they just come out?
oshia86 is offline
post #14 of 108 Old 08-05-2014, 08:42 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Here are the models, older version and newer version:
Old
KF-26
http://www.bestbuy.com/site/klipsch-...5003&cp=1&lp=1
KF-28
http://www.bestbuy.com/site/klipsch-...5003&cp=1&lp=2
New
R-26F
http://www.bestbuy.com/site/klipsch-...5003&cp=1&lp=4
R-28F
http://www.bestbuy.com/site/klipsch-...5003&cp=1&lp=3
I can get the older versions for quite a bit less than what they are listed for on those links.
I don't need something with a ton of bass reach, thats what the subs are for, just something to provide more efficient mids and highs.
Thoughts?
mgrotel is offline
post #15 of 108 Old 08-05-2014, 08:46 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Oh, he always says that Klipsch are bad whether he has heard them or not, so that has no bearing.
Funny, I knew he had authored that post as soon as I started reading it!
psgcdn is offline
post #16 of 108 Old 08-05-2014, 08:47 AM
PM-Performance's Avatar
Quoted: 246 Post(s)
Liked: 142
Old
KF-26
KF-28
New
R-26F
R-28F
Thoughts?
You guys are mixing completely different speakers. This guy is the only one who has it right.
The "old ones" you are referring to are ICON series.
The "new ones" you are referring to are a newer cheapened up version of the Reference series
I had the Icons and currently have the Reference Vii's. I saw the RF-28's and 26's this weekend and immediately shook my head in disgrace as I noticed they cheapened the grills and feet to match the Icons.
Not sure on the driver specs, but I hope they kept those on par with the Vii's
If it were me, I would try to score some vii's from AVS and go with the 82's. I enjoy the bigger drivers over the smaller I had before. ( i had 26's and went to 82's)
Also I just sold my Icon's last week. I could barely give those damn things away. I thought they were pretty good speakers, but nice upgrade to the Reference line for sure
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
post #17 of 108 Old 08-05-2014, 08:50 AM
oshia86's Avatar
Quoted: 12 Post(s)
Liked: 99
No way should you pay those prices for any of those speakers. FYI, I got my F-30's for $200 each, about 1/3 of the price of some of the other options listed here. Call some of the vendors here, as they can generally give you an awesome deal. Also, it seems the KF-28/F-30/R-28F are essentially the same speaker with a different look. I really like my F-30's and didn't think the cost difference of going to a Reference series speaker was worth the price difference, and I've heard the new R-28F's in store and really didn't like them. I really don't think Best Buy does anything other than plugging the speakers into a small amp as their demo's really tend to suck.
oshia86 is offline
post #18 of 108 Old 08-05-2014, 08:59 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
I can get those Icons much cheaper than the price listed in the links. Do you guys think the new R26 and R28 with the copper drivers are the same drivers from the reference series? I would think so since they named it a reference speaker. I am pretty sure these cheapened versions are replacing the Icon line.
mgrotel is offline
post #19 of 108 Old 08-05-2014, 09:01 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Oh, and someone asked what receiver I am using, Denon 2112.
mgrotel is offline
post #20 of 108 Old 08-05-2014, 09:06 AM
oshia86's Avatar
Quoted: 12 Post(s)
Liked: 99
No, from what all I can tell, and what I've heard, they are the Icon speakers with some new paint. Don't think of them as dressed down Reference speakers but dressed up Icon speakers.
Ray77085 likes this.
oshia86 is offline
post #21 of 108 Old 08-05-2014, 09:09 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Ok, thanks, that is good to know, so probably not much of an upgrade then?
mgrotel is offline
post #22 of 108 Old 08-05-2014, 09:23 AM
oshia86's Avatar
Quoted: 12 Post(s)
Liked: 99
I've only heard the Pioneers in a Best Buy setup, which really doesn't do any speaker justice. From what I've heard though, my F-30's are a good upgrade from the Pioneers, but I wouldn't pay that price for them.
oshia86 is offline
post #23 of 108 Old 08-05-2014, 09:28 AM
oshia86's Avatar
Quoted: 12 Post(s)
Liked: 99
Do you have a budget? EMP Tek's stuff seems pretty popular for it's price range. They are probably what I'd go with when I decide to upgrade.
oshia86 is offline
post #24 of 108 Old 08-05-2014, 09:36 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Well, I don't really need to upgrade. I was just in best buy looking at TVs and say the Icons on sale for very cheap, and I mean very cheap, so I started thinking. I guess I would like to stay under 500 for the three speakers, otherwise not sure I want to upgrade right now. Maybe I should just wait.
mgrotel is offline
post #25 of 108 Old 08-05-2014, 09:48 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
And when I say cheap, I mean about 150 off the link I posted a little bit ago for the KF-26s
mgrotel is offline
post #26 of 108 Old 08-05-2014, 10:19 AM
Quoted: 246 Post(s)
Liked: 142
I just confirmed from their site they are indeed dressed up ICON's
The drivers on the Ref IV are Cerametallic and these are IMG woofers.
I didnt check the specs on the tweeter, but that and the looks say enough for me.
post #27 of 108 Old 08-05-2014, 10:30 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
So you say get the previous years' Icons?
Here is what I can get:
2 KF-28s and KC-25 center for total of $383
2 KF-26s and KC-25 center for total of $300
Thoughts?
mgrotel is offline
post #28 of 108 Old 08-05-2014, 10:34 AM
Quoted: 246 Post(s)
Liked: 142
Thoughts?
I would get the Prev year Ref, but thats a significantly diff price range. That budget wont even buy the center channel. lol
But from the looks of things, it might be worth saving the money and getting the ICON's. I would get the 28's though.
post #29 of 108 Old 08-05-2014, 10:36 AM - Thread Starter
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
ok, thanks.
mgrotel is offline
post #30 of 108 Old 08-05-2014, 10:38 AM
Lamont Lashley's Avatar
Liked: 0
The reference ii is better 62ii fronts and 62ii center is a nice set up
Lamont Lashley is offline
Reply Speakers
R-26f , r26f
