Totem Kin and Denon 2113ci, good match? or How to match speakers to a receiver? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By RayGuy
  • 1 Post By ClawAndTalon
  • 1 Post By mtn-tech
post #1 of 6 Old 08-06-2014, 11:49 AM - Thread Starter
JavMcGee's Avatar
I currently have the Denon 2113ci avr receiver and looking at buying the Totem Kin in wall speakers. How do you know if they will be a good match (power wise) or if you need an amplifier? The avr is rated at 95 watts per channel and the speakers are rated at 100 watts. But will the receiver have enough power? The ohms are rated differently (8 ohm receiver, 6 ohm speakers) and the frequency responses are different as well (20 Hz- 20 kHz receiver, 67 Hz- 40 kHz speakers). Apologies if I am asking a stupid question or doing an apples to orange type comparison.
Appreciate any guidance on trying to match speakers to receiver as well.
JavMcGee is offline
post #2 of 6 Old 08-06-2014, 12:04 PM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
The Denon has plenty of power for your speakers. You wont use anywhere near 95 watts unless you have a massive room. The Totem Kin inwall speakers have a sensitivity of 91db or 92db so they're very easy to drive. Doesn't take much power to get them loud.
You can't add an external amp to the Denon 2113 anyway...
Afro GT
afrogt is offline
post #3 of 6 Old 08-06-2014, 12:09 PM
RayGuy's Avatar
Quoted: 892 Post(s)
Liked: 761
Those speakers are 91 dB efficiency. Unless you are going to really crank it up, you should be fine with that receiver. That said, many manufacturers are not very truthful regarding their actual power capabilities (not accusing Denon specifically, it's an industry-wide issue) when all channels are driven, so the proof will be in the using....
JavMcGee likes this.
RayGuy is offline
post #4 of 6 Old 08-06-2014, 12:40 PM
ClawAndTalon's Avatar
Quoted: 408 Post(s)
Liked: 270
Do it now, Totem makes the best architectural speakers on the market IMPO... You'll love it.
ClawAndTalon is offline
post #5 of 6 Old 08-06-2014, 03:59 PM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
You stated the question well - all the info needed to answer.
Others discussed the sensitivity of your speakers - in case you don't understand speaker sensitivity, your speakers will reach a volume of 91dB at 1 meter with 2.83v input (1 watt assuming 8 ohms) - that is really loud for a 1 watt input and your AVR will barely break a sweat event at very loud listening levels.
The other part of your question was the power and impedance rating. As long as the average power you sent to your speaker doesn't exceed its rated power you will be fine - and that is average which could include much higher peak levels. With speakers that sensitive, you will most likely not be using more than 5 - 10 watts. Here is a SPL calculator you can play with:
http://myhometheater.homestead.com/splcalculator.html
Your AVR is rated 95W at 8 Ohms / 125W at 6 Ohms for all channels - the fact that your AVR has a 6 Ohm rating indicates that is rated to drive 6 Ohm speakers. Even if it wasn't rated to drive them, it would anyway (especially because it is a Denon) but it might get hot and shut down. If you have any worries about load impedance, you should consider the ventilation to your AVR and just watch how hot it gets. Your speakers are rated at 6 Ohms, but they also make an additional comment "Easy impedance 6 ohm load (8 ohm in woofer range)" which means that only the low current part of the speakers driver array (probably the mids and tweeters) dip to 6 Ohms and the woofers (which require more current to drive) are closer to 8 ohms.
No problems here, they are very well matched - enjoy your new speakers. I've never heard Totem speakers and didn't even know they had fully enclosed in-wall speakers - wish I could hear what they sound like!
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #6 of 6 Old 08-06-2014, 04:07 PM - Thread Starter
JavMcGee's Avatar
Thanks for the responses everyone! I think this is going to be my new set up and finalizing with the installers tomorrow!
JavMcGee is offline
Reply Speakers
