welp, i've got a dilemma - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By afrogt
  • 1 Post By zieglj01
  • 1 Post By afrogt
  • 1 Post By arnyk
post #1 of 19 Old 08-06-2014, 01:59 PM - Thread Starter
bob2299's Avatar
Exclamation welp, i've got a dilemma
As you can see from the picture, my cat found my speaker
problem is, I don't know if speaker parts exist or if yamaha still does repairs since their discontinued.
help?
bob2299 is offline
post #2 of 19 Old 08-06-2014, 02:27 PM
afrogt's Avatar
Quoted: 671 Post(s)
Liked: 569
We don't either since you didn't mention what speaker that is....impossible to help you.
Craig Peer likes this.
Afro GT
afrogt is offline
post #3 of 19 Old 08-06-2014, 03:17 PM
zieglj01's Avatar
Quoted: 910 Post(s)
Liked: 809
There are companies and online companies that can repair the surround
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is offline
post #4 of 19 Old 08-06-2014, 03:52 PM - Thread Starter
bob2299's Avatar
totally forgot
Yamaha NS777
bob2299 is offline
post #5 of 19 Old 08-06-2014, 04:15 PM
zieglj01's Avatar
Quoted: 910 Post(s)
Liked: 809
Originally Posted by bob2299 View Post
totally forgot
Yamaha NS777
2 places to check - for repairs
http://www.simplyspeakers.com/yamaha...t-fsk-6.5.html
http://www.speakerrepair.com/page/ca...iaphragms.html
Who AM I
zieglj01 is offline
post #6 of 19 Old 08-06-2014, 04:23 PM - Thread Starter
bob2299's Avatar
thanks zieg
i should have also said it's an 8" woofer
don't know if the foam would fit
are all cone edges foam?
bob2299 is offline
post #7 of 19 Old 08-06-2014, 04:30 PM
zieglj01's Avatar
Quoted: 910 Post(s)
Liked: 809
thanks zieg
Email or call them - and give them the model number - this is how the process begins
darthray likes this.
Who AM I
zieglj01 is offline
post #8 of 19 Old 08-06-2014, 04:33 PM - Thread Starter
bob2299's Avatar
thanks
one last thing, is the speaker safe to use like this?
bob2299 is offline
post #9 of 19 Old 08-06-2014, 05:17 PM
dsrussell's Avatar
Quoted: 1810 Post(s)
Liked: 2188
I think it would be best if you call Orange County Speaker Repair (the 2nd URL aieglj01 gave you) and explain the problem. I'm sure they could re-edge it. Playing it as is will only create more problems and possibly bigger tears.
dsrussell is offline
post #10 of 19 Old 08-06-2014, 05:51 PM
gene c353's Avatar
Quoted: 130 Post(s)
Liked: 96
thanks zieg
Rubber is also used instead of foam. You can re-foam speakers yourself. There are how-to video's on youtube. You can also find used drivers on ebay but if you plan on keeping the speakers re-foaming them will make them good as new. You might want to consider doing the other speaker as well if they're a few years old.
gene c353 is offline
post #11 of 19 Old 08-06-2014, 07:37 PM
darthray's Avatar
Quoted: 686 Post(s)
Liked: 595
+1
And might cause the internal parts, like the coil or the spider to start rubbing and creating more Damages
Ray
darthray is offline
post #12 of 19 Old 08-06-2014, 07:41 PM
darthray's Avatar
Quoted: 686 Post(s)
Liked: 595
help?
I feel sorry for you.
I got 3 cats and they never touch my speakers or cables but none have front claws (all rescued).
Best of luck Buddy.
Ray
darthray is offline
post #13 of 19 Old 08-06-2014, 08:12 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 137
Those speakers are not that old. There's a good chance that Yamaha will have some spare drivers laying around.
Gmash is offline
post #14 of 19 Old 08-06-2014, 09:00 PM
afrogt's Avatar
Quoted: 671 Post(s)
Liked: 569
and leave the grilles on when you get them repaired!
dsrussell likes this.
Afro GT
afrogt is offline
post #15 of 19 Old 08-06-2014, 09:13 PM
basshead81's Avatar
Quoted: 115 Post(s)
Liked: 3639
Just put a dab of silicone on the tears and put the grillz back on. Worst case is put new foam surround kit on the driver. I have repaired dozens of drivers...not that difficult.
Www.speakerworks.com
basshead81 is offline
post #16 of 19 Old 08-07-2014, 04:51 PM
jdcrox's Avatar
Quoted: 74 Post(s)
Liked: 99
Yep, a little silicone RTV applied with a finger, gently. You can even get different colors, black would probably look best. You arent going to hurt anything, there is still plenty of surround left properly support the cone, your only real concern is air leakage. Hence the Silicone!
jdcrox is offline
post #17 of 19 Old 08-08-2014, 01:02 AM - Thread Starter
bob2299's Avatar
what type of silicone rtv do I use for speaker foam repair, soft or medium, I'm not sure. Need some help.
bob2299 is offline
post #18 of 19 Old 08-08-2014, 02:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1232
thanks
If it sounds good, its more than safe, its ugly but usable indefinitely.
What you have is primarily a leak in the speaker enclosure. The most likely harm would be a whistling sound during heavy bass.
The holes may be small enough to not cause any short or long term problems.
Speaker refoaming is a risky business, especially if you are not well experienced at it.
arnyk is offline
post #19 of 19 Old 08-08-2014, 03:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1232
Soft.
BTW:
http://www.simplyspeakers.com/speake...e-mi-3035.html
zieglj01 likes this.
arnyk is offline
Reply Speakers
taboola here
