Buying speakers for home theater! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By postrokfan
post #1 of 10 Old 08-06-2014, 09:36 PM - Thread Starter
Liked: 0
Ok so i have been looking for a good 5.0 set of speakers for my home theater and so far im zeroed in on the:
Polk Audio RTiA7 High Performance Floorstanding Loudspeaker - Pair (Black)
Polk Audio RTiA3 High Performance Bookshelf Loudspeakers with 6 1/2" Driver - Pair (Black)
Polk Audio CSiA6 High Performance Center Channel Speaker - Each (Black)
My receiver is the Sony STR-DH540 5.2 Channel 4K AV Receiver 725 Watt Receiver and i have two bic america f12 subwoofers. What i want to know is if these speakers are good for listening to music and watching movies ? also is this receiver powerful enough to run everything ? can i get an external amp or something that i can connect to my reciever to boost the output power ?also my budget is about $1200. So guys let me know if im on the right track thank you.
marioafl is offline
post #2 of 10 Old 08-06-2014, 10:00 PM
postrokfan's Avatar
Quoted: 437 Post(s)
Liked: 2427
You need to audition to determine if these are the speakers for you. What I can say is that the RTiA7s are a significant step above Polk's value line. Also, your budget receiver does not have pre-outs so you can't add an external amp. The Polks are fairly efficient however so an external amp isn't really necessary unless your listening space is cavernous.
postrokfan is offline
post #3 of 10 Old 08-06-2014, 10:17 PM - Thread Starter
Liked: 0
What receiver would you recommend for under $500?
marioafl is offline
post #4 of 10 Old 08-06-2014, 10:20 PM
postrokfan's Avatar
Quoted: 437 Post(s)
Liked: 2427
Do you still want pre-outs? You will most likely need to go refurbished in that price range.
post #5 of 10 Old 08-06-2014, 10:27 PM
crn3371's Avatar
Quoted: 196 Post(s)
Liked: 159
No specific recommendation (although I'm partial to Yamaha). I would suggest looking for a closeout, open box, or refurb on last years model. The only reason I'd look for a new model would be for future proofing (Dolby Atmos, 4k, etc). Something with pre outs would give you the ability to add an external amp.
crn3371 is offline
post #6 of 10 Old 08-06-2014, 10:47 PM
curtissp's Avatar
Quoted: 72 Post(s)
Liked: 3
Like everyone has told you in the other threads you need to get a better receiver if you're going to power a mid range to high performance speakers.
You can have the best fastest car in the world but if you don't have a smart driver that knows how to race what he is tuning then they'll be useless.
(Rules to live by best to over power a speaker then under power it.)
curtissp is offline
post #7 of 10 Old 08-07-2014, 04:56 AM - Thread Starter
Liked: 0
what receivers do you recommend ?
marioafl is offline
post #8 of 10 Old 08-07-2014, 05:05 AM
Transmaniacon's Avatar
Quoted: 1486 Post(s)
Liked: 1279
You don't need an external amp unless you finding yourself needing more volume. How far away would you be sitting from these speakers? One good thing to consider is buying the previous RTi, not RTiA, series from Polks official Ebay store. You get them brand new with a warranty, and the speakers are essentially the same. With the savings, you could get yourself a receiver with pre-outs (just in case).
RTi10: http://www.ebay.com/itm/Polk-Audio-R...item540cc7e549
CSi5: http://www.ebay.com/itm/Polk-Audio-C...item5407478d62
RTi6: http://www.ebay.com/itm/Polk-Audio-R...item5afe4d20ec
Receiver: http://www.accessories4less.com/make...airplay/1.html
You can also go with the bigger RTi12 if you want.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is online now
post #9 of 10 Old 08-07-2014, 07:55 PM
postrokfan's Avatar
Quoted: 437 Post(s)
Liked: 2427
The Marantz SR5008 would be an excellent choice. And, I agree an external amp would not be necessary to power the Polks unless the listening space is huge.
mtn-tech likes this.
post #10 of 10 Old 08-07-2014, 08:04 PM
mtn-tech's Avatar
Quoted: 230 Post(s)
Liked: 176
Great idea - I really liked the previous the RTi version - very well built speakers. These speakers are quite sensitive so it won't take a lot of power to drive them to very loud levels - with sensitive speakers you might want an external amp but you won't need one.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
Reply Speakers
