Replaced NAD 304 amp with Yamaha RX-V473 - now need speakers - AVS Forum | Home Theater Discussions And Reviews
Old 08-07-2014, 11:49 AM - Thread Starter
Liked: 0
Hi,
I had a NAD 304 amp connected to a pair of TDL Near Field Monitor 2 (NF2) Speakers on a couple of speaker stands which I have loved the sound of for many years (20 or more!!), but one channel on the amp started losing volume so I chose to replace the amp for a Yamaha RX-V473 AV amp/receiver (I wanted HDMI/Digital Audio/Airplay etc.)
I am only running the new Yamaha amp in stereo mode for now with Digital Music sources and the TV and the pair of TDL's, but the sound is not a patch on what it was before. The NAD gave a lovely warm, rich and colouful sound through the speakers, whereas I am somewhat disappointed in the Yamaha - it seems rather flat and un-interesting. This surprised me somewhat as I have only read good reviews about the Yamaha amp on the Internet before I purchased it - I am wondering if a speaker upgrade may improve things? The TDL's are now pretty old and perhaps the passive cross over's could be deteriorating (although they sounded OK on the NAD). Unfortunately the RX-V473 does not allow a Bi-Amp Connection to the TDL's (which they can accomodate) which may have improved things by bypassing their passive cross-over, which is a bit frustrating.
Now, I have the Yamaha amp, others say it can sound good, so I would like to try and make the most of it, perhaps with a new speaker setup. I intend to use the system mainly for Stereo music listening but I will most likely look to get 3.1 or 5.1 up and running on it in the future for Movies. The room is a small front room (14ft sq) so I am not looking for anything big, and as ever I don't have much money to spend (£300 or so) but can probably find more to grow it over time.
I will be mainly using it for Stereo Audio, but I also want to try and make the Television Audio soundtrak clearer, so it seems to me that I have several options:
1) Keep the TDL's and supplement with a Sub (might add a bit of richer bass?)
2) Keep the TDL's and supplement with a Center speaker (might benefit TV Audio and give a bit of colour to the Stereo front speakers?)
3) Keep the TDL's and supplement with both a Sub and a Center Speaker (Would give me 3.1 surround option)
4) Replace the TDL's with something else for Stereo and forget about Sub and Center for now
Does anyone have any suggestions for me as to what would sound better than what I currently have?
Thanks in advance for any advice.
Gary
garymansell is offline
Old 08-07-2014, 12:07 PM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1320
Try running the Yamaha in pure direct mode, it may be applying some kind of processing in "music" mode and this could be the difference you are hearing. If you still aren't happy with the sound but enjoyed the NAD before, then you could return the Yamaha and get a NAD receiver, The T748V2 would give you the best of both worlds.
A sub will always help things, but I would check your settings before you make a big change.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 08-07-2014, 12:09 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2994
Some will say that there is a difference in the sound of amplifier units. Some on here will say not. Best to make your own decision on that one.
Yes. A sub would certainly help with bass. New speakers could certainly help. That's often the best way to improve SQ (over putting money into better amplification).
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
