Subwoofer help - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By afrogt
post #1 of 7 Old 08-11-2014, 04:46 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 0
Subwoofer help
Hi, i purchased an Outlaw M8 sub along with Denon X-1000 AVR.
I'm wondering what is the best way to connect these 2 together? Y- cable? or Mono-cable? Also, what is the crossover and frequency behind the Sub? What about the Power option, should i leave it on\off\auto?
i'm totally new to all these audio setting and config, so any inputs would be greatly appreciate.
mh522 is offline
post #2 of 7 Old 08-11-2014, 05:30 PM
afrogt's Avatar
Quoted: 1070 Post(s)
Liked: 776
1. Use a single RCA/Subwoofer cable and plug into the Low Frequency LF (white) input.
2. Flip the switch to Bypass which lets the AV Receiver control the crossover for the sub.
3. Either leave the power switch in the On or Auto position. That's up to you. You'll conserve a little energy by using the Auto position.
If you don't have access to your owners manual you can get it here. It explains things pretty well starting with Page 5.
http://pdf.outlawaudio.com/outlaw/docs/M8_OM.pdf
When calibrating with your Denon x1000 turn the volume on the sub about 1/3 up, about the 10 o'clock position. Then plug the calibration microphone into the Denon and run the Audyssey setup. It'll set the volume levels for the sub and your other speakers as well as the crossover frequency.
There's a Denon X series Owners Thread which you should check for any more help with your receiver. Lots of valuable info in there.
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
Transmaniacon and mh522 like this.
Afro GT
afrogt is online now
post #3 of 7 Old 08-11-2014, 07:00 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 0
Out of curiosity, will i be getting better performance using 1 single subwoofer cable vs White + red RCA cable? As i see they are both available on the M8.
mh522 is offline
post #4 of 7 Old 08-11-2014, 09:15 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 0
any 1 can answer this?
mh522 is offline
post #5 of 7 Old 08-11-2014, 09:26 PM
afrogt's Avatar
Liked: 776
No, you wont get better performance using single vs Y cable, but your x1000 only has a single sub output. You'll be buying a Y cable for no reason except to satisfy your curiosity.
Go ahead and do it as they don't cost that much.
Afro GT
post #6 of 7 Old 08-12-2014, 11:57 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 0
Hi, on my Subwoofer. What is Phase? i have the option to switch between 0 degrees to 180 degrees?
mh522 is offline
post #7 of 7 Old 08-13-2014, 12:39 AM
cel4145's Avatar
Quoted: 2661 Post(s)
Liked: 2993
Leave it on 0. Audyssey will handle the phase when you run it.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
