Active Nearfield Monitors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-11-2014, 05:37 PM - Thread Starter
Liked: 0
I was looking for good, active nearfield studio monitors under £450 and I found the Prodipe Pro 8 V2 monitors. I went to their website and I thought the specifications of the monitors are promising, specially the SPL Vs Freq curve.
The thing is, I never had or bought a proper studio monitor before and I don't have any practical experience. I only know some theories. So...I'm asking you expertises if the monitors are worth buying. I just wanted to know what you guys would think of it. The link to the website is: http://www.prodipe.com/en/products/s...oring-pro-8-v2
I also found a bundle deal here http://www.thomann.de/gb/prodipe_pro...10s_bundle.htm
Many thanks!
Name:	PRO8V2 system curve_2.jpg
Tsegaw is offline
post #2 of 8 Old 08-11-2014, 05:48 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
The plot looks good! I'd say try before you buy. You may not like the sound. True studio monitors are very revealing, by design. That can be both good and bad. I think some Focals are also in that price range which tend to be more well known. Also possibly some Genelec.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #3 of 8 Old 08-11-2014, 06:23 PM - Thread Starter
Liked: 0
I think I can afford Genelic 8020 CMP but the Prodipe pro 8 V2 has better frequency response and curve according to the specs. Trying before buying is good. Thanks!
Tsegaw is offline
post #4 of 8 Old 08-13-2014, 08:06 AM - Thread Starter
Liked: 0
Genelece monitors, 8040B vs 8040A
Which is good for the price?
Tsegaw is offline
post #5 of 8 Old 08-13-2014, 08:40 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Maybe it is just me, but I'm not impressed with what Genelec has to offer in their lower-tier products. Power specs are way too anemic for the price they are charging. Maybe they won't sound as flat as the Genelec but maybe take a look at KRK RoKit or Behringer Truth series for more bang-for-buck. If the OP wasn't in the UK, I'd recommend Emotiva Airmotiv/Stealth monitors. They are an excellent value price vs. performance. Emotiva is phasing out their Stealth 6 monitors at $800 a pair -- that's 210 watts RMS per speaker. They are huge and heavy but that all goes away when I'm pushing music through them.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #6 of 8 Old 08-14-2014, 11:56 AM - Thread Starter
Liked: 0
Yeah, Genelec monitors are very pricey but take a look at the 8240A monitors. They seem to have great specs like ± 1 dB (48 Hz - 20kHz),..and features like Genelec AutoCal™ and Genelec Loudspeaker Manager (GLM™). I should check them out and if I like them I'll definitely save money and buy a pair of them.
Tsegaw is offline
post #7 of 8 Old 08-14-2014, 01:29 PM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
While its good they at least posted something, the frequency response plot is not enough information. Speakers radiate in three dimensions and what we hear some combination of the direct and reflected sound.
The response plot gives no information about the off-axis sound, which judging by the arrangement (8 inch woofer with limited directivity control for the tweeter), will probably have some issues. My recommendation is to go for the JBL LSR 3 series instead.
SyntheticShrimp is offline
post #8 of 8 Old 08-14-2014, 02:41 PM - Thread Starter
Liked: 0
Yes you are right frequency response plot is not enough and I that is why they have this Autocal calibration system. It is very helpful for room response optimization specially if you don't have a proper acoustically treated room.
Even though I'm not sure about what you said about the arrangement of the monitors, their design (arrangement) as they call it directivity controlled waveguide (space around the tweeter) can allow you listen a good frequency response even if you are off-axis a bit. I guess what you said about the arrangement is quite opposite to what they say. But yeah theory is not enough we have to see it practically
Tsegaw is offline
Reply Speakers
