Monitor Audio GX and Ascend Sierra S2 for 2 Channel - AVS Forum | Home Theater Discussions And Reviews
Old 08-12-2014, 09:03 AM - Thread Starter
sheriff of lax's Avatar
Had an opportunity to hear the Monitor Audio GX 100 and liked the fact that the bass or was low enough to not require a sub. Liked the detailed ribbon tweeter.
Has anyone had heard the Ascend S2 with the ribbon tweeter and the ribbon used on the GX series? Also concerned if the Sierra will play as low. I read the specs on each but I never rely on the accuracy of same.
Thoughts?
sheriff of lax is offline
Old 08-12-2014, 09:18 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
The Ascend Sierra-2 uses the RAAL ribbon tweeter which is very good. Monitor Audio doesn't list their tolerance for the frequency response, so the 42Hz they claim doesn't tell you much. The Sierra-2 extends down to 41Hz at -3dB. You could order a pair of the Sierra-2 and see what you think, they have a 30 day trial and all you would pay is return shipping if you send them back.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 08-12-2014, 08:06 PM - Thread Starter
That is what I figured. I like the idea of American made and the bamboo cabinets for their green attributes .
The Monitors have excellent build quality and were surprisingly neutral even though they were paired with a Yamaha receiver.
