Center as a Soundbar? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By niccolo
post #1 of 10 Old 08-13-2014, 02:07 PM - Thread Starter
smile's Avatar
Quoted: 67 Post(s)
I want to improve on my bedroom TV sound but not looking for surround sound solution. I tried a Sony SB but I had a sub to hide and while it sounded OK (except old movies on TCM which carried a hiss I couldn't remove), it required me to adjust the settings every time I changed the channel (and the low mid range was weak- a fatal flaw). I'm just looking for plug and play better TV speakers and wonder if a center will fill the bill. Spending $400 is fine.
smile is offline
post #2 of 10 Old 08-13-2014, 02:13 PM - Thread Starter
smile's Avatar
Quoted: 67 Post(s)
OK, just occured to me a center will not be powered. I'll leave the original post to learn of any ideas.
smile is offline
post #3 of 10 Old 08-13-2014, 02:49 PM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3094
For simple solutions, sound bars and platform speakers may be all you need. But like anything in life, not all sound bars / platform speakers are created equal, as you've found out. Obviously, buying a stereo receiver or AVR and a couple of bookshelf speakers are the best solution, but if you are not willing to go that direction, then checkout higher quality sound bars and platform speakers. Zvox and SpeakerCraft offer better systems. Zvox also has a sub out port.
dsrussell is offline
post #4 of 10 Old 08-13-2014, 02:56 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Another good option is powered, i.e. active speakers, like the Audioengine A5+ and its many competitors. You can get pretty good sound in a small form factor without the extra box of an amp.
dsrussell likes this.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #5 of 10 Old 08-13-2014, 04:42 PM - Thread Starter
smile's Avatar
Quoted: 67 Post(s)
Good thought. And I have a set in my office I can use to test.
smile is offline
post #6 of 10 Old 08-13-2014, 11:05 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
I temporarily used Audioengine A5+s as a two-channel solution in my home theater before I got my current setup, and they sounded remarkably good. Plus the ability to control the volume and mute with the little remote that comes with them was a big plus. They're not cheap, and at their price there are certainly plenty of other options, but as a package deal I think they're pretty compelling. Of course, they're also not tiny, and their much smaller A2 brethren have some more significant sound quality trade-offs.
Rythmik FV15HP sub
niccolo is offline
post #7 of 10 Old 08-14-2014, 06:02 AM - Thread Starter
smile's Avatar
Quoted: 67 Post(s)
Two remotes instead of one is a down side.
smile is offline
post #8 of 10 Old 08-14-2014, 10:10 AM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
So control the volume through the TV.
niccolo is offline
post #9 of 10 Old 08-14-2014, 01:33 PM
RayGuy's Avatar
Quoted: 958 Post(s)
Liked: 820
Alternatively, get a universal / learning remote.
RayGuy is offline
post #10 of 10 Old 08-14-2014, 01:41 PM - Thread Starter
smile's Avatar
Quoted: 67 Post(s)
The M-Audio 40's I just connected via Monitor Out are not controlled by the TV volume controls, evidently. Currently a 2007 50" Pioneer plasma. The speakers don't handle optical so perhaps that digital output would be different. Or a small cheap preamp with remote capabilities.....
smile is offline
Reply Speakers
