3.1 -> 5.1 Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-13-2014, 04:32 PM - Thread Starter
Liked: 0
3.1 -> 5.1 Advice
Hello All!
I'm looking to upgrade my 3.1 HT system to a 5.1. My plan is to move my current front speakers to surrounds and buy new front speakers. I'd like to find a decent pair of floor standing speakers to compliment my current system.
Does anyone have any advice on a pair of front speakers for under $500 that would work well with my system below?
Denon AVR-1611
Energy CB-5 (current front L/R)
Energy CC-5
BIC F12 SUB
Room: Small/Medium
Listening Interests: movies, gaming, music
Thanks for your help!
MrClut is offline
post #2 of 9 Old 08-13-2014, 05:26 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
You should try and stay with Energy so you can use your center channel. Perhaps something like the CF-50 or EF-500, although they might overpower your center.
crn3371 is offline
post #3 of 9 Old 08-13-2014, 08:09 PM - Thread Starter
Liked: 0
So is the center holding me back?
MrClut is offline
post #4 of 9 Old 08-13-2014, 08:33 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
You can always save for a center channel
Look at the Boston M250 - A real good price, $500 a pair - new in the box
http://www.accessories4less.com/make...h-black/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 9 Old 08-13-2014, 09:23 PM
Elihawk's Avatar
Quoted: 1013 Post(s)
Liked: 854
You want your center to match the brand and model of your front speakers, to ensure a timbre natch as sounds move across your front stage. Not all energy speakers will match that particular center...
Elihawk is online now
post #6 of 9 Old 08-13-2014, 10:37 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you want to continue to use the Energy CC-5 center you should look at the CF-30, CF-50 or CF-70.
Don't know where you're located but maybe you can negotiate a deal at Best Buy. No way should you pay full price for those speakers.
If you're in Canada the CF-30 is $199 each.
http://www.futureshop.ca/en-CA/produ.../10111879.aspx
CF-50 $249 each
http://www.futureshop.ca/en-CA/produ...bff200a45aen02
Afro GT
afrogt is online now
post #7 of 9 Old 08-13-2014, 10:46 PM
afrogt's Avatar
Liked: 755
I like the idea of those Boston towers but the center is very expensive.
http://www.accessories4less.com/make...speaker/1.html
Afro GT
post #8 of 9 Old 08-14-2014, 12:13 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
This would be my preference for the center channel - if one can place it, the M25
http://www.accessories4less.com/make...ck-each/1.html
Who AM I
zieglj01 is offline
post #9 of 9 Old 08-15-2014, 12:41 PM - Thread Starter
Liked: 0
Thanks All!
MrClut is offline
Reply Speakers
