Best bookshelves for 250-300 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 66 Old 08-14-2014, 01:00 PM - Thread Starter
Quoted: 71 Post(s)
Liked: 32
I know the budget is slim, but I just spent most money budgeted for speakers on my sub, the Reaction Audio bps-215.
I'm considering the chane m-1s or ARX a1.. Seem to be the best for the money. Any other competitors as good and as cheap?
Edit: realized I out no details of my situation.
I'll be using them for a 2.1 set up run off a budget 100 w/Channel 5.1 receiver. Listening distance is about 10 feet, but will be set up for parties etc, so will need to cover more space then that.
Jafrazi1 is offline
post #2 of 66 Old 08-14-2014, 01:04 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
One speaker that looks good for around that price is the Wavecrest HVL-1. It is just a straightforward, well-behaved bookshelf speaker.
jaeelarr likes this.
shadyJ is offline
post #3 of 66 Old 08-14-2014, 01:14 PM
zieglj01's Avatar
Quoted: 1714 Post(s)
Liked: 1631
A good option is the Definitive SM-450 speaker - and it does measure nice
http://www.newegg.com/Product/Produc...82E16882325060
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 66 Old 08-14-2014, 01:46 PM
swallan's Avatar
Quoted: 12 Post(s)
Liked: 27
agree on the sm450s we had the sm 350s for years a good bang for the buck speaker.
swallan is offline
post #5 of 66 Old 08-14-2014, 01:54 PM
Tstan7777's Avatar
Quoted: 93 Post(s)
Liked: 29
On a budget with a sub???
http://www.crutchfield.com/p_760IMGB...ark-Cherry.htm
Just ordered some b5's so i haven't heard them yet, but they are well regarded. They have some open box ones as well at this moment.
http://www.crutchfield.com/p_760IMGB...Ash.html?cc=02
Tstan7777 is offline
post #6 of 66 Old 08-14-2014, 01:57 PM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
Gee, I feel like a shill since I recommend auditioning this speaker so often, and I don't even own the product: http://hometheaterreview.com/emp-tek...aker-reviewed/
dsrussell is offline
post #7 of 66 Old 08-14-2014, 02:05 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
I suggest the Cambridge Audio SX-50 speakers, for $249 at Crutchfield, Amazon etc.
commsysman is offline
post #8 of 66 Old 08-14-2014, 05:12 PM - Thread Starter
Quoted: 71 Post(s)
Liked: 32
All wonderful suggestions so quick, didn't realize there was such a variety at this price range worth considering. Do those def techs really measure that low? Seems a bit exaggerated for a 6.5 inch woofer..
Jafrazi1 is offline
post #9 of 66 Old 08-14-2014, 05:28 PM
dsrussell's Avatar
Liked: 3095
Sadly, Def Tech is under the impression that they can put any number that passes their fancy into their product specifications and people will believe them. While their reputation is notorious for inflating their numbers to the extreme, they do make pretty good speakers, so they are worth an audition.
post #10 of 66 Old 08-14-2014, 05:29 PM
zieglj01's Avatar
Liked: 1631
No - however, they will go below 50 hz in room response
Who AM I
post #11 of 66 Old 08-14-2014, 06:05 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 437
I think the best thing you can do for that kind of money is to see whats available on craigslist. If I lived where you do I'd never bother with buying new speakers - simply buy the castoffs of those who have to have the next best thing in speakers.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #12 of 66 Old 08-14-2014, 06:19 PM
Nodscene's Avatar
Quoted: 134 Post(s)
I feel the same way as I tend to recommend the HSU speakers even though I don't own them either. I've always wanted to check them out though and will probably grab a pair just to see.
For the OP, here is a link to them.. http://www.hsuresearch.com/products/hb-1.html
I've seen quite a few recommendations from people who's opinion I trust and were really happy with them even though their current speakers were much more expensive. I believe they have a trial period as well which is great.
Edit: Looks like they may be slightly out of your price range at $320 for the pair and then shipping on top of that.
Make something idiot-proof, and they will build a better idiot
Nodscene is offline
post #13 of 66 Old 08-14-2014, 06:24 PM
Elihawk's Avatar
Quoted: 1340 Post(s)
Liked: 1172
I own emp speakers and have heard the bookshelf. If you like neutral, you won't find better for the price. I also own the def tech sm450 and for 200 some dollars, it is a good speaker! Given the choice, I think the EMPtek is better!
Elihawk is offline
post #14 of 66 Old 08-14-2014, 11:46 PM
losservatore's Avatar
Quoted: 2676 Post(s)
Liked: 2452
Speakers should be buy base on your personal preference . Some speakers are warm ,laid back , neutral and forward. Also what type of music you listen more.
I know that at that budget there isn't many options, but you should take that into consideration.
losservatore is offline
post #15 of 66 Old 08-15-2014, 05:03 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
The EMP E5Bi would be a good choice, also take a look at the HTD Level Three bookshelves.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #16 of 66 Old 08-15-2014, 05:52 AM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
Yes at those prices the SM's are fantastic speakers minus what is on paper, but whats on paper is not what you should purchase by. Trust your ears my friend.
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
post #17 of 66 Old 08-15-2014, 05:59 AM
renji1337's Avatar
Quoted: 70 Post(s)
What center matches the def tech 450s?
renji1337 is offline
post #18 of 66 Old 08-15-2014, 06:02 AM
Liked: 1394
The CLR2002, but it's very difficult to find and expensive if you do.
post #19 of 66 Old 08-15-2014, 06:51 AM
afrogt's Avatar
Quoted: 1439 Post(s)
Liked: 983
There are several of the CLR 2002 on ebay.
http://www.ebay.com/sch/i.html?_from...R2002&_sacat=0
zieglj01 likes this.
Afro GT
afrogt is offline
post #20 of 66 Old 08-15-2014, 06:56 AM
Liked: 1394
Good to know! I remember looking for one about 6 months ago when I considering that route and there were hardly any, and the only ones available were $500+
post #21 of 66 Old 08-15-2014, 07:20 AM
djp2k7's Avatar
Quoted: 138 Post(s)
Liked: 62
Yes there are lots of options at that price. Even more if you went up to $400. But you want something loud that will fill a bigger room for parties. I'd suggest the HSU bookshelves. I've had them and they play clean and loud and sound great. But even better yet find something used on Craigslist like someone else said. Something like a vintage Polk Monitor 10 or 7. Incredible speakers that will destroy anything in your budget. Or way way over that imo.
djp2k7 is offline
post #22 of 66 Old 08-15-2014, 09:12 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
+1
The HSUs or the Ascend CBM-170 SEs. Some of the other speakers recommended so far have a bit less sensitivity, which means they would need more power to reach the same volume.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #23 of 66 Old 08-15-2014, 09:19 AM
zieglj01's Avatar
Liked: 1631
The Definitive SM-450 was measured to have 89 db sensitivity - and they will play loud
HSU can/will play loud - however their measured sensitivity was around 86 db average
Some good options here - your choice and call
Who AM I
post #24 of 66 Old 08-15-2014, 09:22 AM
Elihawk's Avatar
Liked: 1172
I was able to get a CLR2002 center for under 300 dollars about 12 months ago. Kind of pricey, since I only paid 200 for the SM450s...but that is one really good center speaker! That system is droven by a Denon 1513 and whether it is power, my room or whatever, the Def Tech system just doesn't get to the volume that my EMP speakers can (and I have swapped AV rec from my theater and living room, so it is not the amplifier). As stated above, Def Tech tends to inflate some of the spect and I suspect these speakers aren't as sensitive as advertised! but still, they sound very good at low to moderately high volume
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #25 of 66 Old 08-15-2014, 09:31 AM
cel4145's Avatar
Liked: 3002
Was it only 86db? Ehh...I knew it was less than the 92db because it is a half space measurements.
For parties, I'd want to have more. I think the Definitive and the Ascends would be the way to go.
cel4145 is offline
post #26 of 66 Old 08-15-2014, 09:48 AM
zieglj01's Avatar
Liked: 1631
HSU MK-2
http://www.soundandvision.com/conten...earch-hb-1-mk2
Who AM I
post #27 of 66 Old 08-15-2014, 09:55 AM
zieglj01's Avatar
Liked: 1631
They tend to be optimistic, stretch the bass specs - not the sensitivity specs
Page 10 measured by DB Keele - they are 89 db sensitive - only 1 db off stated specs - which is good
http://www.theaudiocritic.com/back_i...ritic_29_r.pdf
Who AM I
post #28 of 66 Old 08-15-2014, 10:11 AM
shadyJ's Avatar
Liked: 1352
Keep in mind that sensitivity rating was done in a shootout of bookshelf speakers, and all of them measured about 3 dB lower than their stated spec.
shadyJ is offline
post #29 of 66 Old 08-15-2014, 11:39 AM - Thread Starter
Quoted: 71 Post(s)
Liked: 32
Man you guys are awesome, thank you so much for all the suggestions and information. Learned a lot and haven't even had to ask any questions.
The HSU seem to be the favorite, although most expensive. I am leaning towards these.
Def tech would only be considered due to their low price. A stretch of stats like that is enough for me to want to pass on them. Doesn't make sense to me and is aggravating they think they can do that.
Always heard good things about emp teks. May have to look more into those as well.
I found a pair of klipsch vf-36 in Tennessee for 450. Anyone heard of these towers? Seems to be the only thing available that I would consider locally. I want to make a decision today and make a purchase by tonight. Decisions decisions.
Jafrazi1 is offline
post #30 of 66 Old 08-15-2014, 11:52 AM
zieglj01's Avatar
Liked: 1631
They are not the only ones that do that - most of us do not pay much attention to the
marketing specs - It is the overall performance of the speaker that counts. It is one of
the better deals and sounding speakers on a tight budget.
A lot of speakers measured by a 3rd party show that specs do not tend to match - and
one of them is also Klipsch.
Also, receiver companies are famous for their marketing hype
Your call
Who AM I
Reply Speakers
