Would Energy RC-10 speakers be an upgrade from Klipsch Promedia 2.1s? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By afrogt
  • 2 Post By bekyndnunwind
post #1 of 10 Old 08-19-2014, 05:11 PM - Thread Starter
Liked: 2
Question Would Energy RC-10 speakers be an upgrade from Klipsch Promedia 2.1s?
So, you will probably laugh at me but right now I have a Klipsch Promedia 2.1 setup that I play FLAC files through a USB DAC. To my non-audiophile ears they sound pretty darn good! But I do understand they are sub par.
If I pick up a pair of Energy RC-10 speakers would they sound much better and be a good upgrade? I realize I would need to pick up a decent amp as well (any recommendations?)
My confusion is that according to the SPECs of my Klipsch vs. the Energys, the Klipsch speakers have a wider frequency response. Just don't want to pull the trigger and end up disappointed.
bekyndnunwind is offline
post #2 of 10 Old 08-19-2014, 05:18 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
Definitely an upgrade! Of course if you like the brighter Klipsch sound then maybe you won't like the laid back sound of the RC-10's.
The frequency response of the Promedia is 31hz to 20khz because of the subwoofer. Of course can that sub really hit that low?
Since the RC-10's are only bookshelf speakers with no sub the low end is probably around 50 or 55hz.
Published specs are one thing, actually hearing the speakers in person is quite another.
I wouldn't think twice about upgrade but I own 4 RC-10 speakers.
How much are you willing to spend on a amp/receiver to pair with the RC-10s?
Afro GT
afrogt is offline
post #3 of 10 Old 08-19-2014, 05:29 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
Do it. It will be a nice upgrade no doubt. Might need a sub though depending on what you like to listen to.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #4 of 10 Old 08-19-2014, 05:40 PM - Thread Starter
Liked: 2
Wow, you must really like them if you have 4! Can you recommend a decent amp/receiver to pair with them in the sub $400 range?
post #5 of 10 Old 08-19-2014, 05:56 PM
afrogt's Avatar
Liked: 756
afrogt is offline
post #6 of 10 Old 08-19-2014, 06:07 PM - Thread Starter
Liked: 2
Thanks for the recomendations - I really appreaciate it. I may pull the trigger on the Denon unit and the BIC Formula F-12 tomorrow. Going to sleep on it.
post #7 of 10 Old 08-21-2014, 07:55 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
That would be a monumental upgrade, I have come close on many occasions to buying some RC-10, even though I don't really need them
The RC series was fantastic, it's shame they stopped making them.
Make sure to run Audyssey on your receiver, this is a fantastic read and will help you get the most of your system: "Official" Audyssey thread (FAQ in post #51779)
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #8 of 10 Old 08-21-2014, 07:17 PM
Darrin_R's Avatar
Yep. What AFROGT and TRANSMANIACON said. The Energy RC line has a cult like following, and yes I happen to be one of them.
It really isn't a fair comparison. The Promedia is exactly that, a media speaker designed to be connected to a computer. The RC-10's are designed more for the purist. If you get them, you will be happy.
I wish I would have kept a pair. I had 3 pair.
Read this - http://www.soundstage.com/revequip/energy_rc10.htm
Darrin_R is offline
post #9 of 10 Old 09-16-2014, 06:14 PM - Thread Starter
Liked: 2
I know this is an old thread, but I just wanted to say thanks go all for your feedback (especially afrogt).
Picked up the RC-10s with a Denon AVR-E300 and a BIC F12 sub. Needless to say the sound is amazing!
This setup is great for anyone on a budget looking for great sound. After running the Audyssey calibration and a 100+ hour break-in (I know this may be a myth, but I enjoyed every minute of it) I am in audio heaven. Best upgrade I ever did.
Transmaniacon and Gmash like this.
post #10 of 10 Old 09-16-2014, 10:20 PM
afrogt's Avatar
Liked: 756
Glad you're enjoying your Energy upgrade. It was pretty obvious to us that it would be a huge difference.
Afro GT
afrogt is offline
Reply Speakers
