B&W speaker help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 08-21-2014, 07:01 AM - Thread Starter
Bojik's Avatar
B&W speaker help
I recieved a set of B&W 802 speakers and a B&W HTM center speaker.
I also have a pair of Polk Audio FXIA6.
and I have a powered sub.
I am setting up a media room that is 16' wide by 22' deep and 10' tall.
I missed an auction for some B&W 805 speakers to use a rear speakers. Any suggestions on a set of speakers I could use for rear speakers for under to $1,000 price range. Used is ok.
Bojik is offline
post #2 of 30 Old 08-21-2014, 07:11 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
You can get the B&W CM1 for $1000 if you want to stick with the same brand. I would just keep your eyes open for something used though, speakers at this level are likely taken care of, and you can save yourself some money. Check out www.audiogon.com and www.usaudiomart.com for some deals.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 30 Old 08-21-2014, 07:14 AM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 98
Keep checking audiogon, craigslist, etc. for a used pair of 805's. You definitely want to stay within the 800 line rather than mix and match between lines.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
post #4 of 30 Old 08-21-2014, 09:46 PM - Thread Starter
Bojik's Avatar
Could I use a pair of Dm602?
Bojik is offline
post #5 of 30 Old 08-22-2014, 04:41 AM
Liked: 1394
Your surrounds don't need to match, so those would work fine. They are front ported so you could place them closer to the wall which is nice.
post #6 of 30 Old 08-22-2014, 06:34 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
What exact model of the 802's and HTM do you have? There are so many variations of those they could range from current gen to almost 20 years old.
Rod#S is offline
post #7 of 30 Old 08-22-2014, 07:09 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
What are the Polk's being used for, surrounds? If so then you have a 5.1 setup currently and want to move to 7.1 or are you looking to replace the Polks? If moving from 5.1 to 7.1 with you using Polks as surrounds then timbre matching is not of concern to you so my recommendation would be to just get whatever fits your fancy, style wise and budget. If you can find another pair of those Polks that would work. If looking to replace the Polks and timbre matching is important to you then going with B&W 805's would make sense. I can't see you getting 805 Diamonds for $1000 but it might be possible to come across a really good buy on the older models.
Rod#S is offline
post #8 of 30 Old 08-22-2014, 10:15 AM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1394
Stick to the same brand and range if you can, but IMO rears and surrounds aren't nearly as important as the front stage, so it's okay to mix and match to save money. You probably won't even notice. It's like putting in super nice furnishings in your guest bedroom's bathroom, just not worth the money.
RLBURNSIDE is offline
post #9 of 30 Old 08-25-2014, 05:54 AM
Liked: 1394
That's a great analogy!
post #10 of 30 Old 08-25-2014, 03:29 PM - Thread Starter
Bojik's Avatar
Sorry for now reply, busy few days...
802 Series 3
Matrix HTM
The Polk's will be my mid room speakers (mounted at the ceiling halfway from front to back)
Attached are some pics of the current room. Left & Right side. Back side and a pic of the front, center and sub speaker labels.
Name:	2014-08-25 15.33.17.jpg
ID:	229361   Click image for larger version
Name:	2014-08-25 15.33.24.jpg
ID:	229369   Click image for larger version
Name:	2014-08-25 15.33.40.jpg
ID:	229377   Click image for larger version
ID:	229385   Click image for larger version
Bojik is offline
post #11 of 30 Old 08-25-2014, 03:35 PM - Thread Starter
Bojik's Avatar
I think I will go with the Dm602 unless someone has any solid reason why not.
Bojik is offline
post #12 of 30 Old 08-25-2014, 06:18 PM - Thread Starter
Bojik's Avatar
There are a pair of B&W 685 on ebay for $380 vs the Dm602 for $500. I don't know much about B&M so not sure the difference or which one would suit my needs better.
Bojik is offline
post #13 of 30 Old 08-25-2014, 07:58 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
What version are the DM602s you are looking at? S2? S3? $500 seems kind of steep considering the age of these speakers. $380 for the 685s seems fair depending on condition and hours of use.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #14 of 30 Old 08-25-2014, 08:04 PM - Thread Starter
Bojik's Avatar
Bojik is offline
post #15 of 30 Old 08-25-2014, 08:06 PM - Thread Starter
Bojik's Avatar
Bojik is offline
post #16 of 30 Old 08-25-2014, 08:16 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
These all look like the original DM602s which came out in 1996. Great speaker at the time but pretty old.
post #17 of 30 Old 08-25-2014, 08:18 PM - Thread Starter
Bojik's Avatar
I will do some looking on www.audiogon.com and www.usaudiomart.com (as suggested by Transmaniacon) and see what is there.
Bojik is offline
post #18 of 30 Old 08-25-2014, 08:21 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
The first link shows a dented tweeter. I would bid lower than $380 even though it wouldn't effect the sound too much especially in surround duty.
The second link is for 686s actually and they retailed for $480. These look to be in good shape but are rear ported. I'm not sure if this is a problem for you. A fair price but I'd probably take the 685s over these.
post #19 of 30 Old 08-27-2014, 04:08 AM - Thread Starter
Bojik's Avatar
Here are some CM1 speakers, any thoughts?
http://www.ebay.com/itm/Bowers-Wilki...item20eb48869c
There are also a set of new CM1 speakers for $900
Bojik is offline
post #20 of 30 Old 08-27-2014, 04:28 AM - Thread Starter
Bojik's Avatar
Just noticed the CM1 speakers are rear ported, is this even an option with putting them up against the back wall? Or do I need front ported?
Bojik is offline
post #21 of 30 Old 08-27-2014, 04:33 AM - Thread Starter
Bojik's Avatar
Bojik is offline
post #22 of 30 Old 08-27-2014, 10:32 AM
macddmac's Avatar
Quoted: 16 Post(s)
I had cm-1 in my office on mopads.
Pulled them out so that the baffles were about 2' from the wall and they sounded pretty good 7' apart, 7' to my LP.
Really tough room (10x10x9) and had them situated on a diagonal
To get those spacings. Toe- in didn't change sound.
For optimal imaging, I'd suggest about 2' from the back of the speaker to wall and 2' to sides with a triangle of 6-8'.
They come with 2piece plugs that will help for close wall placement but you'll sacrifice some bass performance using them. Not an issue if using a sub- highly recommended btw
Cheers, Mac
macddmac is offline
post #23 of 30 Old 08-27-2014, 09:22 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
The DM602 S2s are priced pretty high. I would be inclined to go with something a bit cheaper like the 685s if you can find a pair with intact tweeters.
post #24 of 30 Old 08-28-2014, 04:39 AM
Liked: 1394
Yeah he could grab a brand new pair of the S2 version for well under his budget.
post #25 of 30 Old 08-28-2014, 05:58 AM - Thread Starter
Bojik's Avatar
I don't really have the room to move my rear speakers away from the back wall. Does this work with the rear ported speakers like the 685s?
Bojik is offline
post #26 of 30 Old 08-28-2014, 06:11 AM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
The 685s are front-ported. It's the 686s that are rear-ported
post #27 of 30 Old 08-28-2014, 05:52 PM - Thread Starter
Bojik's Avatar
Oops my bad, but same question, can rear ported speakers be put up in the corner as I intend to do?
Bojik is offline
post #28 of 30 Old 08-28-2014, 08:22 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
They can if you install the port plugs but for the best sound they really need some space. For surrounds it's not as critical but still a consideration.
post #29 of 30 Old 08-30-2014, 06:59 AM - Thread Starter
Bojik's Avatar
Found a pair of 602 S3 that are local to me so I could check them out before purchase. But they are the wrong color, would it be a big deal to paint the boxes black?
And is the price ok?
http://www.ebay.com/itm/B-W-602-S3-B...item4adb252de6
Bojik is offline
post #30 of 30 Old 08-30-2014, 08:48 AM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
Again, these cost $600-$650 12 years ago. A more reasonable price if they were in good shape would be $300-$400. If it were me, I don't think I would want to paint over the veneer but that's your call. Since they're local why not give them a listen and see what kind of shape they're in. Perhaps you could talk the owner down on price.
Reply Speakers
802 , 805 , b&w , htm
