Rear Speakers Popping with ANY bass - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-22-2014, 12:26 PM - Thread Starter
Liked: 0
Unhappy Rear Speakers Popping with ANY bass
half a year ago i got pretty cheap rear speakers for my old surround sound setup (everything else works great) and they make a very loud and annoying popping or crackling sound whenever there is even the slightest amount off bass. Are the speakers broken?
These are the speakers:
http://precision-acoustics.com/classic_cb4.php
Tylor Boleychuk is offline
post #2 of 7 Old 08-22-2014, 02:12 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Not necessarily, but if you're sending significant power below 80Hz into a 4 inch driver you can expect that it won't be happy about it.
Bill Fitzmaurice is offline
post #3 of 7 Old 08-22-2014, 03:18 PM - Thread Starter
Liked: 0
how do i stop it from sending below 80hz? use a lower gauge cable?
post #4 of 7 Old 08-22-2014, 05:09 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
No. You set them as "small" in the setup program. That will send the bass to the subwoofer.
FMW is offline
post #5 of 7 Old 08-22-2014, 07:16 PM - Thread Starter
Liked: 0
THANKYOU so much that got rid of all the cracling
post #6 of 7 Old 08-22-2014, 07:21 PM
rcohen's Avatar
Quoted: 1401 Post(s)
Liked: 630
It could either be the speaker reaching its limits or something else in the signal chain clipping.
Either way, that's a good fix.
rcohen is offline
post #7 of 7 Old 08-22-2014, 07:38 PM - Thread Starter
Liked: 0
i have one more question for you guys, i pushed my from speaker way too much a month ago (with bass) and every time there is a bassy voice it makes a high pitched kind of crackling sound. its not noticable in movies and its not that loud in general but i was wondering if i damaged my speaker. (i have re stripped the wire that didn't help)
Reply Speakers
audio , bass , Bookshelf Speakers , Home Theater , speakers
