So I thought I'd posts the spec's for the CX-10's seeing that this is the Reaction Audio thread
10" Coaxial monitor for music and Home Theater
Suited for LCR or surround use. Can also be used as studio monitors or live sound reinforcement
10" woofer with 3" voice coil with center mounted 1.75" compression driver horn
Custom 1300 hz crossover with ERSE capacitors and high grade components
Cast frame baskets and 14 lbs total driver weight
100-350 watts rms recommended power (Can be driven to high levels with even modestly powered receivers!)
Recommended subwoofer crossover - 70 - 100 hz
95 db efficiency 1 watt,1 meter
Frequency Response - 57-18,000 hz +/- 3 db
Max Peak SPL 125 db
90 degree conical high end dispersion
Unmatched Price/Performance ratio
Heavy Duty MDF, 3/4 inch cabinet
Recessed baffles for clean look
3/8 Radius on all sides
Smooth Satin Black Finish
Black magnetic cloth grills
Weight: 38 pounds shipped
Size: 20 H x 12.5 W x 12.5 D
Free Ground Shipping to the lower 48 US states!
30 day in home trial
Warranty: 5 years
