Audioengine A5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-30-2014, 08:30 AM - Thread Starter
Liked: 0
Audioengine A5
I own a set of Audioengine a2 and a5 speakers, things have been very satisfying for me! However, since a week or so my set of a5 speakers started to make a strange noise while playing and even while not playing anything. It sounds like some crackling/popping sounds along with some sort of 'blowing in microphone' sort of sound. I already tried replacing the speaker cables and AC cable. And I used different power outlets along with changing the positions of the speakers. However nothing seems to fix the problem. Could it be a bad capacitor or something?
I can upload a video of the sound it produces, if that would further clarify my issue.
martinussanders is offline
post #2 of 8 Old 08-30-2014, 11:36 AM
postrokfan's Avatar
Quoted: 523 Post(s)
Liked: 3127
It sounds like the amplifier is going south. I would contact Audioengine support. Hopefully they're still under warranty.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is online now
post #3 of 8 Old 08-30-2014, 12:09 PM - Thread Starter
Liked: 0
I think they aren't under warranty anymore. However I tore them apart and saw this one blacked out cable on the PCB, see attachment 1. I reckon it should look like something on the photo of attachment 2. There is a capacitor on the other side of the pcb/burnt wire.
ID:	237418   Click image for larger version
post #4 of 8 Old 08-30-2014, 12:38 PM
postrokfan's Avatar
Quoted: 523 Post(s)
Liked: 3127
That looks like a fairly straightforward repair if you are comfortable with soddering and can find the parts. If not, you could take it to an electronics repair shop. Or option 3, you could contact Audioengine and see if they would do the repair for a fee.
post #5 of 8 Old 08-30-2014, 12:50 PM - Thread Starter
Liked: 0
And what do you reckon the problem is? The faulty/burnt wire or the capacitor underneath? Could a broken capacitor lead to such problems?
post #6 of 8 Old 08-30-2014, 01:00 PM
postrokfan's Avatar
Quoted: 523 Post(s)
Liked: 3127
Hard to say without doing some troubleshooting with a multimeter. After thinking about it and seeing the burnt wire I'm not so sure this is a situation where a repair can be done. Also, if the capacitor has gone bad generally there's some evidence of fluid leaking around the edges.
post #7 of 8 Old 08-30-2014, 01:07 PM - Thread Starter
Liked: 0
I have a multimeter at hand, so measuring would't be a problem. However, while i'm rather handy around electronics I'm not sure wat to measure at this point.
post #8 of 8 Old 08-31-2014, 01:35 PM
postrokfan's Avatar
Quoted: 523 Post(s)
Liked: 3127
Does your meter have the option to check for continuities? If you can, solid connections will measure 0 ohms while shorted or partial connections will measure higher. If you plan to do this make sure the speakers aren't plugged in of course and be aware that capacitors can store energy for quite a while depending on the amp design.
Reply Speakers
